mchencode
#1 Posted : Wednesday, January 25, 2012 5:51:16 PM(UTC)
mchencode
I am currently using your software on trail and it is great.
Though i do have an issue:
I am using 2 Osprey composite input cards and a decklink hd pro as the sdi output.
I am getting an error " Pixel shaders are not supported by the installed graphics hardware" when
i click on start for the external device.
The external output settings are correct for the card and UYVY | VMR9 is selected under Performance.
I'm currently running XP Pro SP2.
I would be grateful for any assistance.
Mark
#2 Posted : Wednesday, January 25, 2012 10:14:57 PM(UTC)
Hi Mark,
What graphics card do you have?
The error message usually means an old graphics card is installed which does not support the external output feature.
mchencode
#3 Posted : Thursday, January 26, 2012 1:01:40 PM(UTC)
mchencode
Hi Martin,
the graphics card is RADEON 9250.
So the error wouldn't be related to the decklink card ? as 'Decklink' appears in the box below
the error.
What graphics hardware would you recommend?
Mark
#4 Posted : Friday, January 27, 2012 4:13:01 AM(UTC)
Any recent graphics card will work fine.
NVIDIA 240GT or 430GT for example.
The DeckLink output requires pixel shaders on the graphics card so that is why that error appears.
