tilman36
#1 Posted : Saturday, January 21, 2012 10:28:29 AM(UTC)
tilman36
Hi everybody,
since a couple of weeks my vmix (no matters wich version) crashes when i try to open a XAML file or a title. "Program is not responding"
Any ideas?
Tilman
#2 Posted : Saturday, January 21, 2012 9:18:07 PM(UTC)
Was thanked: 4708 time(s) in 1613 post(s)
Could you provide a screenshot of the error message?
Thanks,
#3 Posted : Thursday, January 3, 2013 8:40:52 AM(UTC)
First off , everyone all the best for the new year.
Short while ago I discovered vMix and must say I am impressed (trial) but I am now experiencing the same problem as the OP after I have been able to test and play with it with no problems whatsoever.
problems range from delay in loading to black screen (no screen cap possible ;-) ) which is trying to rebuild the screen but fails to even blue screen .
I have tried reinstalling graphic drivers, vMix but nothing seems the help.
the system is a laptop with I7 core 64x, AMD Mobility Radeon HD 5800 series.
any test I can do to help fix this issue ?
Guy
#4 Posted : Thursday, January 3, 2013 9:05:18 AM(UTC)
If you are seeing a completely black screen appear then it sounds like a graphics card issue.
Have you tried playing some recent games to see if they cause the same issue?
#5 Posted : Thursday, January 3, 2013 9:43:13 AM(UTC)
Agree it has something to do with the graphics issue (hence reinstalling video driver etc) but I don't play games so how do I check, but do a lot of video analysis ( coaching) .
Yesterday I was able to play with the titles even as loaded first with no problems at all ( editing titles and testing in attempt to figure out the xaml) .
Occasionally I would have a timeout error while loading them.
While currently I keep crashing (the screen is trying to rebuild itself) I changed to starting vMix(64) but started first loading a video and capture source, added virtual set and then a title... worked until I started again with first loading a title ... crash. Now it started crashing again after first loading the other sources.
#6 Posted : Thursday, January 17, 2013 3:42:26 PM(UTC)
Update:
Clean installed Windows 7 (x64), latest GPU drivers (dual ATI H5870)
Various stress tests all fine.
vMix and Xaml (titles etc) still crashes display.
As per Windows tips and many others changed Tdrelay register setting: at times managing to start with xaml but still eventually crashing .
Other tip : disable PowerPlay
So far all looks good, able to play and test vMix & Xaml :-)
fingers crossed
Guy
