melody
#1 Posted : Friday, January 6, 2012 2:17:41 PM(UTC)
Rank: Guest
Groups: Guests
hi martin,
during recording when click "quick play" some frames are dropped. this happens 4 or 5 times at a 3h (more or less) recording.
is here something that i`m doing wrong or it is a bug?
regards,
melody
www.espiritosanto.cc
#2 Posted : Friday, January 6, 2012 11:35:15 PM(UTC)
Was thanked: 4788 time(s) in 1643 post(s)
What are the two inputs you are using Quick Play between?
#3 Posted : Friday, January 6, 2012 11:51:06 PM(UTC)
Also, please provide a small video clip of a recording that shows the transition issue.
melody
#4 Posted : Saturday, January 7, 2012 7:48:06 AM(UTC)
Rank: Guest
Groups: Guests
ok, here goes the video demo...
?hd=1
the 2 inputs involved are 2 sony fx-7e cams (both firewire connected) with the same settings. this issue happens sometimes doesnt matter the source, just happens at final frames of transition.
in adobe premiere, after dropped frames, theres a little unsync in video/audio that can be fixed by add a fixed image from last frame, it is showed in the video.
hope it help, regards,
melody
#5 Posted : Saturday, January 7, 2012 9:01:12 AM(UTC)
I will need a copy of the clip around the area where the fade occurs. So please render a short clip and provide it in AVI or mp4 format.
Looking at that video though my guess would be the Virtual GenLock has been disabled?
melody
#6 Posted : Saturday, January 7, 2012 12:41:25 PM(UTC)
Rank: Guest
Groups: Guests
hi,
i splitted a chunk from original recorded file around the area the fade occurs, can be downloaded below...
http://www.megaupload.com/?d=NAQKJGHO
Virtual GenLock is enable on both cameras.
regards,
melody
#7 Posted : Saturday, January 7, 2012 1:12:38 PM(UTC)
Thanks,
A couple of more questions:
1. What CPU and graphics card is in the machine?
2. Does the dropped frame show up in the vMix window as well or just the recording?
melody
#8 Posted : Saturday, January 7, 2012 1:32:46 PM(UTC)
Rank: Guest
Groups: Guests
1. CPU - Intel i7 920 2.67Ghz
GPU - ATI Radeon HD 5750 1Go
2. dropped frame show on both
regards,
melody
#9 Posted : Sunday, January 8, 2012 2:59:20 AM(UTC)
Have a try of the new version and see if it helps:
http://forums.vmix.com.au/default.aspx?g=posts&t=285
Similar Topics
Slow motion transition issue (Instant Replay)
by petervk 10/20/2018 10:54:10 PM(UTC)
random transition issue (General Discussion)
by Guest 11/3/2011 6:39:54 AM(UTC)
