Rank: Guest
Groups: Guests
hi martin, during recording when click "quick play" some frames are dropped. this happens 4 or 5 times at a 3h (more or less) recording. is here something that i`m doing wrong or it is a bug? regards, melody www.espiritosanto.cc
Joined: 1/13/2010(UTC) Posts: 5,323  Location: Gold Coast, Australia Was thanked: 4727 time(s) in 1619 post(s)
What are the two inputs you are using Quick Play between?
Also, please provide a small video clip of a recording that shows the transition issue.
Rank: Guest
Groups: Guests
ok, here goes the video demo... ?hd=1 the 2 inputs involved are 2 sony fx-7e cams (both firewire connected) with the same settings. this issue happens sometimes doesnt matter the source, just happens at final frames of transition. in adobe premiere, after dropped frames, theres a little unsync in video/audio that can be fixed by add a fixed image from last frame, it is showed in the video. hope it help, regards, melody www.espiritosanto.cc
I will need a copy of the clip around the area where the fade occurs. So please render a short clip and provide it in AVI or mp4 format. Looking at that video though my guess would be the Virtual GenLock has been disabled?
Martin vMix
Rank: Guest
Groups: Guests
Thanks,
A couple of more questions:
1. What CPU and graphics card is in the machine? 2. Does the dropped frame show up in the vMix window as well or just the recording?
Martin vMix
Rank: Guest
Groups: Guests
1. CPU - Intel i7 920 2.67Ghz GPU - ATI Radeon HD 5750 1Go 2. dropped frame show on both regards, melody www.espiritosanto.cc
