PFBM
#1 Posted : Friday, October 17, 2014 10:43:09 AM(UTC)
PFBM
* Onboard deinterlacing on Magewell cards is now automatically disabled
as vMix supports automatic deinterlacing internally.
Hi Martin,
hardware deinterlace of magewell cards works better than vmix deinterlace.
because sharpness option disables vmix deinterlace......
its better to use magewell hardware deinterlace this way.
now i have manually reactivate deinterlace on the card.....
not very pratical..... :(
Best regards,
PFBM
PFBM
#2 Posted : Saturday, October 18, 2014 7:37:55 PM(UTC)
PFBM
Hi Martin,
Best regards,
PFBM
Please Martin :(
is there any setting on config file ?
PFBM
#3 Posted : Tuesday, October 21, 2014 7:39:57 PM(UTC)
PFBM
atpt wrote:
As I also have a Magewel I will wait for a reply to update from version 13 to 14
There will be an update soon to fix it :)
#4 Posted : Tuesday, October 21, 2014 10:31:09 PM(UTC)
Was thanked: 4674 time(s) in 1609 post(s)
atpt wrote:
As I also have a Magewell I will wait for a reply to update from version 13 to 14
The fix is only for a specific issue where you use the Sharpen effect on interlaced magewell sources.
Can you confirm what issues you are having, as this fix should not affect most users?
Thanks,
melody
#5 Posted : Wednesday, October 22, 2014 6:54:17 AM(UTC)
Rank: Guest
Groups: Guests
maybe a check box on settings for hardware deinterlace feature would respond to all users
regards,
melody
www.espiritosanto.cc
PFBM
#6 Posted : Wednesday, October 22, 2014 7:26:16 AM(UTC)
PFBM
regards,
melody
Yep !
there has allways been the problem between vmix deinterlace and sharpness
a hardware check box should do it.
on some cards that also have hardware image control , should also have this option.
Best regards,
PFBM
PFBM
#7 Posted : Wednesday, October 22, 2014 9:33:21 AM(UTC)
PFBM
here is another example of one of the best capture cards on the market :
http://www.ospreyvideo.c...osprey-cards/osprey-460e
Pre-Processing:
Logo/bitmap overlay
Closed-caption extraction/rendering
Logo/bitmap overlay
Scaling, cropping, de-interlacing and inverse telecine
Loss of video automatic test pattern generation with text overlay option
all Hardware stuff on the card just as is on Magewell cards.
Best regards,
PFBM
PFBM
#8 Posted : Thursday, October 23, 2014 9:20:13 AM(UTC)
PFBM
Magewell cards hardware processing :
Color Space Switch
De-interlacing Vertical filter de-interlacing; motion-adaptive de-interlacing
Image Scale Hardware 5-Tap scale
Image Mirror Horizontal; vertical
Image Clip Yes
Image Adjustment Brightness/contrast/hue adjustment/
saturation adjustment/control of monochrome and color/
Gamma adjustment
separately adjust the brightness and contrast of R/G/B
Guest (5)
