Please put back Magewel deinterlace :(
Joined: 3/30/2011(UTC) Posts: 311  Location: Portugal Thanks: 360 times Was thanked: 37 time(s) in 31 post(s)
* Onboard deinterlacing on Magewell cards is now automatically disabled as vMix supports automatic deinterlacing internally.
Hi Martin,
hardware deinterlace of magewell cards works better than vmix deinterlace. because sharpness option disables vmix deinterlace...... its better to use magewell hardware deinterlace this way. now i have manually reactivate deinterlace on the card..... not very pratical..... :(
Best regards,
PFBM
Hi Martin,
Best regards,
PFBM
Please Martin :( is there any setting on config file ?
atpt wrote:As I also have a Magewel I will wait for a reply to update from version 13 to 14 Thanks There will be an update soon to fix it :)
Joined: 1/13/2010(UTC) Posts: 5,316  Location: Gold Coast, Australia Was thanked: 4718 time(s) in 1616 post(s)
atpt wrote:As I also have a Magewell I will wait for a reply to update from version 13 to 14 Thanks The fix is only for a specific issue where you use the Sharpen effect on interlaced magewell sources. Can you confirm what issues you are having, as this fix should not affect most users? Thanks, Martin vMix
Rank: Guest
maybe a check box on settings for hardware deinterlace feature would respond to all users regards, melody www.espiritosanto.cc
melody wrote:maybe a check box on settings for hardware deinterlace feature would respond to all users regards, melody www.espiritosanto.cc Yep ! there has allways been the problem between vmix deinterlace and sharpness a hardware check box should do it. on some cards that also have hardware image control , should also have this option. Best regards, PFBM
here is another example of one of the best capture cards on the market : http://www.ospreyvideo.c...osprey-cards/osprey-460ePre-Processing: Logo/bitmap overlay Closed-caption extraction/rendering Logo/bitmap overlay Scaling, cropping, de-interlacing and inverse telecine Loss of video automatic test pattern generation with text overlay option all Hardware stuff on the card just as is on Magewell cards. Best regards, PFBM
Magewell cards hardware processing :
Color Space Switch
De-interlacing Vertical filter de-interlacing; motion-adaptive de-interlacing
Image Scale Hardware 5-Tap scale Image Mirror Horizontal; vertical Image Clip Yes
Image Adjustment Brightness/contrast/hue adjustment/ saturation adjustment/control of monochrome and color/
Gamma adjustment separately adjust the brightness and contrast of R/G/B
