2 Pages<12
sg93
#21 Posted : Friday, November 20, 2026 4:43:36 AM(UTC)
sg93
Germany
Originally Posted by: Dist Go to Quoted Post
Originally Posted by: sg93 Go to Quoted Post
In the ReplayAPI only the tag of the selected camera is shown. This maybe come in handy in some situations but it would be preferable if all tags were available with the tag of the active camera being in a separate data point
Have you tried ReplayEventsAPI? That provides all events data such as every single event, and the description (tag) of every single camera, and which cameras are enabled. So that provides all the event data, and in combination with ReplayAPI (or the main XML api, as the ReplayAPI is just a subset of that), will provide you with the playback data of what's currently selected, should be everything you need.
Yes. unfortunately it doesn't help because it doesn't change depending on which event is selected
#22 Posted : Friday, November 20, 2026 5:12:23 AM(UTC)
The vMix API gives you the ID of the selected event, the Number of the selected camera and the tag of the selected
Based on the ID one can pull all the tags from that event and which angles are set from the ReplayEventsAPI
sg93
#23 Posted : Saturday, November 21, 2026 1:16:39 AM(UTC)
sg93
Germany
Thats more of "hack" and creates an unnecessary step. Why not just include all information of the current event in the API anyway? :)
Dist
#24 Posted : Saturday, November 21, 2026 2:43:23 AM(UTC)
Dist
Was thanked: 28 time(s) in 20 post(s)
Not really a hack, more so different sources for different information.
For example the XML endpoint provides the data needed for things such as this
This is what a lot of replay setups need, so that they can have parity with other replay systems that provide this data, they don't necessarily need the events data to show the state of every single camera/tag currently playing.
This is an example of the Events endpoint showing a single event (and you would need twice this as there's channels A and B).
Code:
<event>
<inPoint>-193859946</inPoint>
<outPoint>4665651678</outPoint>
<description>someTag</description>
<description>-</description>
<selectedAngles>True</selectedAngles>
<selectedAngles>False</selectedAngles>
<id>4</id>
<speed>-1</speed>
</event>
If you need events data as well as replay data, poll them both, if you don't need events data you don't need to request it. I'd rather they didn't bloat the XML and ReplayXML endpoints with all of that data as that's a lot of data (in relation to the rest of the payload), and it's infrequently updating so wouldn't need to be polled as frequently as XML or ReplayXML.
Personally I don't think the inconvenience of needing to poll 2 different endpoints for different data outweighs the benefits of the data being split in this way as you can still get the data you need.
sg93
#25 Posted : Saturday, November 21, 2026 3:26:08 AM(UTC)
sg93
Germany
Code:
<event>
<id>4</id>
<speed>-1</speed>
</event>
I don't think you understand my point.
It's not about polling two different endpoints.
The thing is ReplayAPI updates the content of the same row as the played event changes. ReplayEventsAPI basically is a static ordered list of events. I have no benefit using it in my case.
I want to play a list of events, have the data of the playing event shown in a title and updating the data as the event changes.
#26 Posted : Saturday, November 21, 2026 5:05:26 AM(UTC)
I dont understand the issue
If you poll ( with a datasource ) you get the info updated as the (multiple) events are played out
xpath //input[@type="Replay" ]//channel[1] that you can link to your title
sergkov
#27 Posted : Monday, November 23, 2026 8:01:23 AM(UTC)
sergkov
Germany
​When setting up Fullscreen for a projector (via HDMI Nvidia 4080), I typically select a specific Input (Output) as the source so I can make color and gamma adjustments. Occasionally, the projector displays a black screen as if no signal is being sent. Switching the Fullscreen source back to Output 1 immediately restores the signal.
GuilhermeArruda
#28 Posted : Monday, November 23, 2026 1:13:45 PM(UTC)
GuilhermeArruda
Brazil
The "Use high quality deinterlacing where available" option causes issues with replay outputs when enabled.
#29 Posted : Monday, November 23, 2026 8:30:57 PM(UTC)
Can you please describe the issue, as this should already be fixed in the latest updates.
GuilhermeArruda
#30 Posted : Tuesday, November 24, 2026 12:22:47 PM(UTC)
GuilhermeArruda
Brazil
I can no longer reproduce the issue, but this is what it looked like when it occurred:
Master Frame Rate: 1080p59.94
Source shown in the image: 1080i59.94 (SRT H264)
2 Pages<12
