2 Pages<12
sg93
#21 Posted : Friday, November 20, 2026 4:43:36 AM(UTC)
sg93
Germany
Originally Posted by: Dist Go to Quoted Post
Originally Posted by: sg93 Go to Quoted Post
In the ReplayAPI only the tag of the selected camera is shown. This maybe come in handy in some situations but it would be preferable if all tags were available with the tag of the active camera being in a separate data point
Have you tried ReplayEventsAPI? That provides all events data such as every single event, and the description (tag) of every single camera, and which cameras are enabled. So that provides all the event data, and in combination with ReplayAPI (or the main XML api, as the ReplayAPI is just a subset of that), will provide you with the playback data of what's currently selected, should be everything you need.
Yes. unfortunately it doesn't help because it doesn't change depending on which event is selected
#22 Posted : Friday, November 20, 2026 5:12:23 AM(UTC)
The vMix API gives you the ID of the selected event, the Number of the selected camera and the tag of the selected
Based on the ID one can pull all the tags from that event and which angles are set from the ReplayEventsAPI
2 Pages<12
