Joined: 5/7/2012(UTC) Posts: 185  Location: Bucharest Thanks: 48 times Was thanked: 13 time(s) in 11 post(s)
We are preparing to jump :)
Any advice on 4K livestreaming over the Internet ? Anyone here did it?
We'll be able to use vMix for a such project ?
Thank you,
Joined: 11/30/2013(UTC) Posts: 165 Location: Seoul, South Korea
Thanks: 39 times Was thanked: 19 time(s) in 14 post(s)
I would have serious doubts that the average person's computer would be able to handle this kind of resolution, especially in a Flash RTMP environment. What is the scenario you have in mind? Who is your stream destination?
Absolutely right :) In fact, many times there are problems with HD resolution in livestreaming. In our project the destination is a 4K cinema venue and we should be able to control the internet connection at both ends.
Joined: 10/25/2012(UTC) Posts: 181 Location: Barbados
I have done 1080 to a cinema for a live sports event with success using vMix. The Key, al least in my scenario, was adequate Bandwidth and/Encode/Decode process.
Maxi
 1 user thanked Maximus for this useful post.
Maximus wrote:I have done 1080 to a cinema for a live sports event with success using vMix. The Key, al least in my scenario, was adequate Bandwidth and/Encode/Decode process.
Maxi
We stream 1080 all the time, even over our 3G modem. But only at 3 megabit :) I'm sure you can also stream 4K at 3 or 4 megabit, but i'd rather stream 1080 10 mbit then :)
 1 user thanked Ittaidv for this useful post.
Maximus wrote:.... and/Encode/Decode process... Thank you.. Anything special in Encode/Decode process other then FMLE ?
FMLE is a horribly inefficient encoder, I recommend you use FFMPEG. If you have control of your internet connection at both ends, I suggest using the "-preset" option with a value like "superfast".
I *think* the HEVC encoder (libx265) supports that. I've used it in libx264 with success to lower CPU usage at the expense of compression efficiency.
 1 user thanked lbgaus for this useful post.
Maximus wrote: .... and/Encode/Decode process...
One Word. Zixi
I also try to use Hardware Encoder/Decoder, but last project was done using FMLE
Maxi
