ClementN
#1 Posted : Saturday, September 20, 2014 9:50:48 AM(UTC)
ClementN
Romania
We are preparing to jump :)
Any advice on 4K livestreaming over the Internet ? Anyone here did it?
We'll be able to use vMix for a such project ?
Thank you,
lbgaus
#2 Posted : Saturday, September 20, 2014 11:28:14 AM(UTC)
lbgaus
I would have serious doubts that the average person's computer would be able to handle this kind of resolution, especially in a Flash RTMP environment. What is the scenario you have in mind? Who is your stream destination?
ClementN
#3 Posted : Saturday, September 20, 2014 11:33:05 AM(UTC)
ClementN
Romania
Absolutely right :) In fact, many times there are problems with HD resolution in livestreaming.
In our project the destination is a 4K cinema venue and we should be able to control the internet connection at both ends.
Maximus
#4 Posted : Saturday, September 20, 2014 11:59:56 AM(UTC)
Maximus
I have done 1080 to a cinema for a live sports event with success using vMix. The Key, al least in my scenario, was adequate Bandwidth and/Encode/Decode process.
Maxi
thanks 1 user thanked Maximus for this useful post.
ClementN on 9/20/2014(UTC)
Ittaidv
#5 Posted : Saturday, September 20, 2014 12:07:41 PM(UTC)
Ittaidv
Maxi
We stream 1080 all the time, even over our 3G modem. But only at 3 megabit :) I'm sure you can also stream 4K at 3 or 4 megabit, but i'd rather stream 1080 10 mbit then :)
thanks 1 user thanked Ittaidv for this useful post.
ClementN
#6 Posted : Saturday, September 20, 2014 12:20:21 PM(UTC)
ClementN
Romania
Maximus wrote:
.... and/Encode/Decode process...
Thank you.. Anything special in Encode/Decode process other then FMLE ?
lbgaus
#7 Posted : Saturday, September 20, 2014 12:40:49 PM(UTC)
lbgaus
FMLE is a horribly inefficient encoder, I recommend you use FFMPEG. If you have control of your internet connection at both ends, I suggest using the "-preset" option with a value like "superfast".
I *think* the HEVC encoder (libx265) supports that. I've used it in libx264 with success to lower CPU usage at the expense of compression efficiency.
thanks 1 user thanked lbgaus for this useful post.
Maximus
#8 Posted : Saturday, September 20, 2014 5:51:12 PM(UTC)
Maximus
One Word. Zixi
I also try to use Hardware Encoder/Decoder, but last project was done using FMLE
Maxi
