fluozh
#1 Posted : Tuesday, August 11, 2026 7:31:08 PM(UTC)
fluozh
Japan
Posting this in case it’s useful for anyone testing OMT with vMix 29.
I put together a small open-source suite similar in role to NDI Tools, but for OMT:
Studio Monitor – discover and view OMT sources on the local network
Test Patterns – send SMPTE-style video patterns and tone over OMT
Screen Capture – WIP
Main use case for me is quick source checks and feeding a known pattern into vMix without depending on another software source.
GitHub: https://github.com/MikanseiLaboratory/omt-tools
Still early. Happy to take bug reports if something doesn’t behave with vMix OMT input/output.
thanks 3 users thanked fluozh for this useful post.
Peter1000 on 8/12/2026(UTC), jet on 8/26/2026(UTC), sinc747 on 9/24/2026(UTC)
jet
#2 Posted : Wednesday, August 26, 2026 5:27:37 AM(UTC)
jet
Was thanked: 27 time(s) in 25 post(s)
Great Toolset for OMT!
At it's early days it's already beating NDI equivalent by offering animated Test Patterns with selectable frame rates!
Thanks!
Roy Sinclair
#3 Posted : Thursday, September 24, 2026 7:06:12 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
Does your Studio Monitor allow the video to be directed to a specific monitor on systems that have multiple monitors?
And please tell me that it uses the same monitor numbers that Windows shows when you use "Identify" in the Settings> System > Display page. NDI Tools don't and the numbers it uses are different between a cold boot (from powered off system) and a warm boot (reboot a powered on system), very annoying.
fluozh
#4 Posted : Thursday, September 24, 2026 6:19:32 PM(UTC)
fluozh
Japan
I didn't get what you want for this. Can you give it a try and open an issue on GitHub in case it does not implement what you want to use?
jet
#5 Posted : Sunday, October 11, 2026 8:24:43 PM(UTC)
jet
There seems be a problem with the Apple silicon version:
When run says something like "the package is damaged".
Intel version works..
I hope the Apple silicon version will also work soon, because intel apps are no more supported on new macOS releases.
It seems that the issue is in "omt-launcher" - other apps seem to be intact, but not runnable.
thanks 1 user thanked jet for this useful post.
fluozh on 10/11/2026(UTC)
fluozh
#6 Posted : Sunday, October 11, 2026 9:33:29 PM(UTC)
fluozh
Japan
Hi, thank you for the feedback!
I'll support it soon. Unfortunately I only have old Intel-gen MacBook Air so I couldn't test the real installer.
Potentially it runs from built from source code, but I'll take a look.
Also it'll be very helpful for me if you could open an issue on GitHub :)
Thank you for your valuable feedback!
Guest, ultraklang
