Joined: 3/18/2021(UTC) Posts: 45   Location: Tokyo Thanks: 19 times Was thanked: 14 time(s) in 11 post(s)
Posting this in case it’s useful for anyone testing OMT with vMix 29. I put together a small open-source suite similar in role to NDI Tools, but for OMT: Studio Monitor – discover and view OMT sources on the local network Test Patterns – send SMPTE-style video patterns and tone over OMT Screen Capture – WIP Main use case for me is quick source checks and feeding a known pattern into vMix without depending on another software source. GitHub: https://github.com/MikanseiLaboratory/omt-toolsStill early. Happy to take bug reports if something doesn’t behave with vMix OMT input/output.
 3 users thanked fluozh for this useful post.
Joined: 11/14/2012(UTC) Posts: 413  Location: Finland Thanks: 270 times Was thanked: 40 time(s) in 38 post(s)
Great Toolset for OMT!
At it's early days it's already beating NDI equivalent by offering animated Test Patterns with selectable frame rates!
Thanks!
 1 user thanked jet for this useful post.
Joined: 11/23/2020(UTC) Posts: 252  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: fluozh  Posting this in case it’s useful for anyone testing OMT with vMix 29. I put together a small open-source suite similar in role to NDI Tools, but for OMT: Studio Monitor – discover and view OMT sources on the local network Test Patterns – send SMPTE-style video patterns and tone over OMT Screen Capture – WIP Main use case for me is quick source checks and feeding a known pattern into vMix without depending on another software source. GitHub: https://github.com/MikanseiLaboratory/omt-toolsStill early. Happy to take bug reports if something doesn’t behave with vMix OMT input/output. Does your Studio Monitor allow the video to be directed to a specific monitor on systems that have multiple monitors? And please tell me that it uses the same monitor numbers that Windows shows when you use "Identify" in the Settings> System > Display page. NDI Tools don't and the numbers it uses are different between a cold boot (from powered off system) and a warm boot (reboot a powered on system), very annoying.
I didn't get what you want for this. Can you give it a try and open an issue on GitHub in case it does not implement what you want to use?
I put together a small open-source suite similar in role to NDI Tools, but for OMT There seems be a problem with the Apple silicon version: When run says something like "the package is damaged". Intel version works.. I hope the Apple silicon version will also work soon, because intel apps are no more supported on new macOS releases. It seems that the issue is in "omt-launcher" - other apps seem to be intact, but not runnable.
Originally Posted by: jet  Originally Posted by: fluozh  Posting this in case it’s useful for anyone testing OMT with vMix 29.
I put together a small open-source suite similar in role to NDI Tools, but for OMT There seems be a problem with the Apple silicon version: When run says something like "the package is damaged". Intel version works.. I hope the Apple silicon version will also work soon, because intel apps are no more supported on new macOS releases. It seems that the issue is in "omt-launcher" - other apps seem to be intact, but not runnable. Hi, thank you for the feedback! I'll support it soon. Unfortunately I only have old Intel-gen MacBook Air so I couldn't test the real installer. Potentially it runs from built from source code, but I'll take a look. Also it'll be very helpful for me if you could open an issue on GitHub :) Thank you for your valuable feedback!
 1 user thanked fluozh for this useful post.
Originally Posted by: fluozh  Originally Posted by: jet  Originally Posted by: fluozh  Posting this in case it’s useful for anyone testing OMT with vMix 29.
I put together a small open-source suite similar in role to NDI Tools, but for OMT There seems be a problem with the Apple silicon version: When run says something like "the package is damaged". Intel version works.. I hope the Apple silicon version will also work soon, because intel apps are no more supported on new macOS releases. It seems that the issue is in "omt-launcher" - other apps seem to be intact, but not runnable. Hi, thank you for the feedback! I'll support it soon. Unfortunately I only have old Intel-gen MacBook Air so I couldn't test the real installer. Potentially it runs from built from source code, but I'll take a look. Also it'll be very helpful for me if you could open an issue on GitHub :) Thank you for your valuable feedback! Thanks! Don't yet have a GitHub account. When is the working Apple silicon version available? Kind regards, Jani
 2 users thanked fluozh for this useful post.
jet on 11/11/2026(UTC), Follo on 11/12/2026(UTC)
Joined: 10/10/2019(UTC) Posts: 65   Location: Düsseldorf Thanks: 5 times Was thanked: 17 time(s) in 10 post(s)
Just tested the Studio Monitor, works great.Thanks for your work.
Best regards
Michel
 1 user thanked Follo for this useful post.
