Joined: 3/18/2021(UTC) Posts: 38   Location: Tokyo Thanks: 13 times Was thanked: 9 time(s) in 8 post(s)
Posting this in case it’s useful for anyone testing OMT with vMix 29. I put together a small open-source suite similar in role to NDI Tools, but for OMT: Studio Monitor – discover and view OMT sources on the local network Test Patterns – send SMPTE-style video patterns and tone over OMT Screen Capture – WIP Main use case for me is quick source checks and feeding a known pattern into vMix without depending on another software source. GitHub: https://github.com/MikanseiLaboratory/omt-toolsStill early. Happy to take bug reports if something doesn’t behave with vMix OMT input/output.
 2 users thanked fluozh for this useful post.
Joined: 11/14/2012(UTC) Posts: 367  Location: Finland Thanks: 236 times Was thanked: 25 time(s) in 23 post(s)
Great Toolset for OMT!
At it's early days it's already beating NDI equivalent by offering animated Test Patterns with selectable frame rates!
Thanks!
Joined: 11/23/2020(UTC) Posts: 244  Location: Wichita Thanks: 13 times Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: fluozh  Posting this in case it’s useful for anyone testing OMT with vMix 29. I put together a small open-source suite similar in role to NDI Tools, but for OMT: Studio Monitor – discover and view OMT sources on the local network Test Patterns – send SMPTE-style video patterns and tone over OMT Screen Capture – WIP Main use case for me is quick source checks and feeding a known pattern into vMix without depending on another software source. GitHub: https://github.com/MikanseiLaboratory/omt-toolsStill early. Happy to take bug reports if something doesn’t behave with vMix OMT input/output. Does your Studio Monitor allow the video to be directed to a specific monitor on systems that have multiple monitors? And please tell me that it uses the same monitor numbers that Windows shows when you use "Identify" in the Settings> System > Display page. NDI Tools don't and the numbers it uses are different between a cold boot (from powered off system) and a warm boot (reboot a powered on system), very annoying.
