kricher1964
#1 Posted : Monday, October 5, 2026 10:56:18 AM(UTC)
kricher1964
Was thanked: 13 time(s) in 4 post(s)
I have two inputs that I always use for a starting lineup graphic. For each new game I delete the old graphics (inputs) and add the new grpahics (inputs) in the same place that the old ones were located. FWIW Away Team is always input 30 and the Home Team is always input 31.
WhenI look at the shortcuts, they always are correct and work pefectly after the inputs are updated. However, the activators do not. When I look at the activators after the inputs are updated, they have the correct input number (30 or 31) but they do not have the name. They just say "30" or "31." Therefore the activator doesn't work properly until I re-select the input from the dropdown list.
It's a minor thing and I know how to quickly correct it but it feels like inconsistent bahaviour. If the shortcut works and always has the correct input after the inputs have been updated, then the activator should as well.
