voiceovercity
#1 Posted : Tuesday, June 18, 2024 7:33:51 AM(UTC)
voiceovercity
I thought there was a time when I could add images to a list and they would default to 5-seconds. Now I don't see this and I'm wondering if maybe I'm thinking of something else.
Basically, I can build a list AND include images, but because they don't have a time associated with them, they will stop the list from playing. When the image is displayed, the playout will simply stop. There's no error and I can click the forward button to make it go to the next asset, but it would be great if there was a way to have to assign a time to images.
Thanks.
#2 Posted : Tuesday, June 18, 2024 7:43:10 AM(UTC)
Thanks.
Believe you mean "PlayList"
Double click on the item in the playlist to get a settings window for it
doa
#3 Posted : Tuesday, April 14, 2026 5:45:56 PM(UTC)
doa
Netherlands
This will not work if you use a list input. They are only for playback video and audio.
To use this option you have to use a playlist. See bottom row LEFT from the overlay in vMix
#4 Posted : Wednesday, April 15, 2026 8:52:02 PM(UTC)
@ voiceovercity
Why not use the Photos Input and adjust with the SlideShow Settings?
Henny
#5 Posted : Wednesday, April 15, 2026 10:50:18 PM(UTC)
Henny
Was thanked: 28 time(s) in 24 post(s)
some time back i did do a script that looked at a list input and checked it current item had a duration of 0 it waited a set time then advanced the list to the next item , it let me mix videos and stills in a list imput
I dont have a copy of it to hand
