Setting run-time for static images in lists
Joined: 4/20/2017(UTC) Posts: 19 Location: Atlanta, GA
Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
I thought there was a time when I could add images to a list and they would default to 5-seconds. Now I don't see this and I'm wondering if maybe I'm thinking of something else.
Basically, I can build a list AND include images, but because they don't have a time associated with them, they will stop the list from playing. When the image is displayed, the playout will simply stop. There's no error and I can click the forward button to make it go to the next asset, but it would be great if there was a way to have to assign a time to images.
Thanks.
Originally Posted by: voiceovercity  I thought there was a time when I could add images to a list and they would default to 5-seconds. Now I don't see this and I'm wondering if maybe I'm thinking of something else.
Thanks.
Believe you mean "PlayList" Double click on the item in the playlist to get a settings window for it
Joined: 6/16/2013(UTC) Posts: 15   Location: Netherlands,Lelystad Thanks: 27 times Was thanked: 1 time(s) in 1 post(s)
This will not work if you use a list input. They are only for playback video and audio. To use this option you have to use a playlist. See bottom row LEFT from the overlay in vMix
@ voiceovercity
Why not use the Photos Input and adjust with the SlideShow Settings?
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
some time back i did do a script that looked at a list input and checked it current item had a duration of 0 it waited a set time then advanced the list to the next item , it let me mix videos and stills in a list imput I dont have a copy of it to hand
