53 Pages«<50515253>
mairginter@hotmail.com
#1021 Posted : Friday, March 27, 2026 2:09:50 AM(UTC)
Italy
Hi @raugert,
I’ve been thinking about the Bitfocus Companion integration and wanted to share some ideas with you.
From what I’ve seen on GitHub, it doesn’t look like a Feedback API integration will be available anytime soon. Because of that, I’d like to suggest a workaround that I believe is the cleanest approach.
My idea revolves entirely around the Satellite API.
Companion allows you to create a button that essentially references another button, and it also mirrors feedback elements such as button color and text.
With that in mind, all buttons needed in Panel Builder could be placed on a dedicated Companion page (e.g., "vMixPanelBuilder") and referenced there. Panel Builder could then use the Satellite API to integrate these buttons—including button color, text color, labels, etc.—cleanly and with proper live updates. There would even be a way to integrate rotary encoders as touch sliders.
I’m not sure how much development effort this would require or whether this is something you’re interested in at all, but I wanted to share the idea anyway. I really like your tool, and since I still rely on Companion as well, I’m always looking for a more customizable and visually clear interface than what Companion currently offers.
Best regards,
Alex
Kotin
#1022 Posted : Friday, March 27, 2026 5:39:07 AM(UTC)
Kotin
Hi Alex,
​I was reading your thoughts on using the Satellite API to get live feedback into a custom UI. It's a very clever workaround, as getting real-time state sync (colors, text, faders) out of vMix and into a clean dashboard is definitely a known challenge.
​Since you mentioned you are actively looking for a "visually clear interface" with proper live updates, I wanted to share a free tool I recently developed that might interest you. It’s called VRC (Video Recording Control Hub).
​Instead of relying on middleware, I built it natively on Windows (WinUI 3) to connect directly to the vMix TCP/XML API. Because of this, it inherently has instant live feedback for everything: input states, SRT routing, and active audio faders (including Volume, L/R channels, and Gain) without needing Companion as a bridge.
​Panel Builder is a legendary tool, but if you are looking for a highly dense, modern UI specifically designed to monitor and control vMix nodes with real-time feedback out of the box, you might find VRC useful for your workflow.
​You can check out the releases and UI screenshots here: https://github.com/Kotin-ak/VRC-Releases
​Best regards,
Alexander
#1023 Posted : Friday, March 27, 2026 5:49:07 AM(UTC)
Italy
Originally Posted by: Kotin Go to Quoted Post
Hi Alex,
​Best regards,
Alexander
Thanks for the hint Kotlin. I had already seen your tool, and I’ll definitely take a closer look at it when I get the chance.
What I really need, though, is a very flexible and clearly structured UI—similar to what Panel Builder offers. Ideally, I’d also like to integrate Bitfocus Companion buttons, including reliable feedback and state handling. Unfortunately, Companion’s TCP API currently doesn’t seem to provide all the capabilities required for this.
Kotin
#1024 Posted : Friday, March 27, 2026 7:24:08 AM(UTC)
Kotin
​Hi Alex,
​That makes total sense! VRC has a very dense, fixed layout for engineering, so if you need a drag-and-drop, free-canvas dashboard like Panel Builder, VRC definitely won't replace that visually for you.
​However, regarding your struggle with Companion’s TCP API lacking reliable feedback and state handling — that is exactly the headache I ran into, which forced me to build the background logic of VRC.
​Just as a side note for your project: VRC actually runs a local HTTP Control API and a SignalR Hub (/hubs/control) in the background. It takes all the heavy, complex vMix XML/TCP data and translates it into clean, real-time state broadcasts. The SignalR hub pushes ButtonFeedback (including on/off states and HEX colors) and ActivatorEvent payloads directly to external clients. It even has a native Elgato Stream Deck plugin built around this.
​So while VRC might not be your front-end UI, it could potentially act as that reliable "state-handling middleware" for your Companion setup if you ever decide to pull data from a clean REST/SignalR endpoint instead of directly fighting the vMix TCP API.
​Good luck with the integration! It's a very cool concept you are building.
​Best,
Alexander
raugert
#1025 Posted : Saturday, March 28, 2026 12:49:44 AM(UTC)
raugert
Canada
Originally Posted by: mairginter@hotmail.com Go to Quoted Post
Hi @raugert,
Best regards,
Alex
Thanks for the suggestion Alex. The issue with BitFocus Companion's API is not that it doesn't report the button color feedback. It actually does, and Panel Builder is able to capture and parse the TCP results from the Bitfocus API. The problem is that it only sends a message with the "CHANGES" when a button changes color. Now the REAL issue is that I need a way to get the "current color" state of the buttons that contain feedback in order to set the Initial button colors when "Loading" a Panel Builder template. I've discovered that this actually happens when a device is disconnected then reconnected. The Bitfocus API sends a message listing the state of all the buttons containing feedback for that device.
So.. The current work around is to program a button ( I chose 1/3/0) with Press actions to disconnect and then reconnect the device. This way I get the color state of all the Buttons that contain feedback. Now I can set them in Panel Builder. Some folks are successfully using this method in Panel Builder to trigger BitFocus buttons and get the tallies to work properly.
Ideally, it would be nice to have an API function in BitFocus that requests this information without having to program a disconnect and reconnect of a device within a Button.
Richard
#1026 Posted : Saturday, March 28, 2026 2:14:37 AM(UTC)
Italy
Thanks for the feedback, @Raugert.
As I already mentioned earlier, I can’t get the feedback working at all anymore — not even with your trick. It worked perfectly fine until some time ago, and then it suddenly stopped.
Sometimes a Bitfocus button just turns red and never updates again. The press actions, however, still work perfectly fine.
This is also the reason why I wanted to give you a little nudge in this direction 🙂 — and because I’d really love to use things like text feedback and similar features.
Do you have any idea what else I could try?
I’m pretty sure the issue is on the Companion side, since I’ve already tested all versions of the Panel Builder that I have, with the same result.
dmwkr
#1027 Posted : Friday, May 1, 2026 2:11:18 AM(UTC)
dmwkr
Was thanked: 160 time(s) in 144 post(s)
Originally Posted by: dmwkr Go to Quoted Post
Originally Posted by: raugert Go to Quoted Post
UPDATE: Version 4.0.62
Change log:
BitFocus buttons are now compatible with new format intoduced inBitFocus3.3(Page,Row,Column) --use Bitfocus version 3.4.0 Beta for compatibility
Hi Richard,
I was just testing out the BitFocus buttons feature. Could it be that the iOS Panel Builder app does not support this new format (Page, Row, Column) yet? Or am I missing something? The buttons are working fine on Mac OS, but not on iOS.
Thank you!
Hi Richard,
I was getting back to testing this with the current versions on iOS and Android, and here is a more detailed report:
When pressing a button on iOS/Android, Companion adds this entry to the log:
Code:
Service/Tcp: TCP command failed. Error: Deprecated commands are disabled
When enabling the Deprecated TCP API in the Companion settings, this is the message in the log:
Code:
Service/Tcp: TCP command failed. Error: Page/bank out of range
raugert
#1028 Posted : Friday, May 1, 2026 9:56:51 PM(UTC)
raugert
Canada
Until now the old button format was still supported even though it was deprecated. It has been removed altogether from the Bitfocus API in the latest version. Yes indeed, I will need to update the iOS and Android versions.
Richard
Luis70
#1029 Posted : Friday, September 25, 2026 8:51:49 PM(UTC)
Luis70
Grenada
Was thanked: 11 time(s) in 11 post(s)
Hi there Raugert, Anything new to try...has been a long time since we had something new from you ...
raugert
#1030 Posted : Sunday, September 27, 2026 2:25:57 AM(UTC)
raugert
Canada
Sorry, I haven't been doing much broadcast work in the past year, so coding wasn't top of mind. I'm not even sure if people are still using the app. I have no way of monitoring that, as it doesn't record or send any user data. I've been retired for 15 years but continued to do some side gigs until recently, but now I have other priorities. Maybe it's time for me to really retire. :) I'll see how it goes it the next little while...
Richard
Luis70
#1031 Posted : Sunday, September 27, 2026 8:14:15 AM(UTC)
Luis70
Grenada
ok...you know how some persons, like me, love this app...time Not to retire...keep your beain active...lol....maybe you should take a poll to see how may persons still use this great app... there is nothing like it, nothing ...
luis70
thanks 1 user thanked Luis70 for this useful post.
jet on 9/27/2026(UTC)
#1032 Posted : Tuesday, September 29, 2026 10:29:11 AM(UTC)
Italy
@Raugert
First of all, thank you, Richard, for all the work you’ve put into Panel Builder over the years. I’ve used your tool for a very long time, and it has been a key part of my workflow. Even now, there’s still nothing quite like it.
I honestly expected that at some point you might slow down a bit
In the meantime, with the possibilities of modern AI tooling, I built a small alternative for myself — not as a replacement, but as a different conceptual approach. The biggest architectural change is that I use Bitfocus Companion as the central logic layer, and my project is only a web-based UI, similar in spirit to Panel Builder, but much thinner. The UI simply triggers Companion actions and reads Companion feedback via the Satellite API.
If anyone is curious, here’s the repo:
👉 https://github.com/mairginter/companion-webpanel
Screenshot 2026-09-29 022617.png (783kb) downloaded 99 time(s).
A couple of functions from the project that might be interesting:
Live Button Feedback via Satellite API
The panel mirrors Companion button states (text, colors, visibility) in real time without custom polling logic.
Dynamic UI Generation
Buttons, sliders, and text fields are generated from a JSON layout that references Companion button IDs — making it easy to build new dashboards quickly.
Touch Slider → Virtual Encoder
A web-based slider can act as a Companion encoder and trigger actions accordingly.
Your tool has inspired a lot of people, including me — and even if you decide to fully retire, your work will continue to be appreciated.
@Luis70
I completely agree with you — Panel Builder is still unique, and many of us continue to rely on it. But I also fully understand Richard’s situation. After so many years of retirement, continuing development is a huge commitment.
Whether he keeps going or decides to enjoy a well‑earned full retirement, his contribution to the vMix community has been exceptional.
Luis70
#1033 Posted : Tuesday, September 29, 2026 8:40:26 PM(UTC)
Luis70
Grenada
can we have the app to try out... just want something to keep my brain active, and this looks like what can keep me up all night, just like Panel Builder....just give us the link to this app
Update...I found it...sorry...
#1034 Posted : Wednesday, September 30, 2026 4:02:56 AM(UTC)
Italy
Hi @Luis70
Of course, feel free to test it! The app is publicly available on GitHub, and you can download the latest version from the Releases section.
Just keep in mind that it’s still a work in progress. There are a few things I want to optimize and simplify. Some of the current features will probably hardly ever be used and mostly make the app unnecessarily complicated.
The audio meters are also still bothering me. The current solution is far too complicated and requires too much effort, so I’m looking for a much simpler way to implement them.
Here’s the GitHub release:
https://github.com/mairg...anel/releases/tag/v1.4.1
PS: You can also download an AI README directly from the app. Give it to your favorite chatbot and you can ask questions about the app directly.
Have fun playing around with it!
Alex
Luis70
#1035 Posted : Wednesday, September 30, 2026 9:56:01 AM(UTC)
Luis70
Grenada
Hi, I am having issues creating buttons, plus the instructions are not very clear...need help
#1036 Posted : Wednesday, September 30, 2026 11:04:51 AM(UTC)
Italy
Hi, can you give me a bit more detail about what’s not working? What exactly is unclear when creating the buttons?
And is the chatbot giving you bad or inaccurate answers even with the help-me-KI-by_alex.md file available?
#1037 Posted : Thursday, October 1, 2026 5:52:47 AM(UTC)
Italy
I've updated the README on GitHub and released v1.5.1:
The help file is now in English and starts with a Getting Started guide (requirements, your first panel in 6 steps, common first-time problems). You can get it in two ways:
directly on GitHub: help-me-KI-by_alex.md
in the app: "Download Help" in the start window, below the version number
Tip: Just give the file to an AI assistant (ChatGPT, Claude, Gemini, Copilot…) and ask your questions in plain language. The file includes instructions for the AI, so it can walk you through your specific setup.
Quick steps to create a button:
1. In Companion, go to Settings → Protocols and enable the Button Subscriptions API (requires Companion 4.3+).
2. In the panel, click the hosts icon in the toolbar and add your Companion host (IP, port 16623). A green dot means it's connected.
3. Switch to Edit mode (E), then Toolbar → Add element → CompanionButton.
4. In the Properties panel on the right, pick Host, Page, Row and Col.
5. Save with Ctrl+S, then switch to View mode (V) and tap to press.
Gruß Alex
Luis70
#1038 Posted : Thursday, October 1, 2026 7:28:52 PM(UTC)
Luis70
Grenada
Is there an ALL ENGLISH translation for the buttons on the UI...cannot understand what some of the labels are saying
dmwkr
#1039 Posted : Thursday, October 1, 2026 7:56:53 PM(UTC)
dmwkr
Sorry to interrupt, but maybe you want to open a new thread for your app (looks great, btw), so users don't get confused, especially new users. Thanks!
Luis70
#1040 Posted : Thursday, November 26, 2026 12:08:33 AM(UTC)
Luis70
Grenada
Hi all, am having real difficulties with Panel Builder on one of my PCs...it functions as it should, but I get NO Tallys telling me what I am doing, and when I close it, I have the same options to 'Save and Quit' 'Cancel', 'Discard and Quit', but for some unknown reason, I get NO response for any of the buttons, and have to click on the 'X' again to close or use Task Manager... have any body here ever had that issue, and what is your advice...first time in as many years Panel Builder was around I have this issue
Guest (4)
53 Pages«<50515253>
