Hello everyone,
I have tried to reduce the number of devices used for audio Master and BUS A for VmixCall. The Magewell AES 67 is USB audio with a routing matrix that allows you use it for in and for out on different ways. I route 2 XLR balanced inputs from 2 mics to USB (as audio input in vmix) and BUS A from Vmix via USB to Analog outputs 2 XLR for 2 IEMs. My problem is that this device doesn't refuses to work sometimes. One time is not giving output , other time is not routing input to VMIX. I have use it also with Zoom. Sometime it works sometime doesen't. The advantage consist in the fact that you ca use One single device in one single USB port. As system I use ASUS ROG i9 (new generation) Windows 10 ( more stable in my opinion), Vmix 4k up to date Have someone tried Magewell AES 67? Have you had similar problems? Do you know other similar device as AES 67 Magewell?
I have been in a bad situation during a live surgery transmission when suddenly the audio collapsed...
I appreciate any opinion.
Thank you.
Never used mine via USB. Why do you not use it via ethernet and NDI instead?
Never tried, but I will. you can set Audio Bus A in NDI? How does appear in the AES 67 matrix? As stream? Thank you
Richard, Do you use one AES 67 both as in and out? I have managet tu use in as NDI input in Vmix by enabling TX NDI Type unicast , IP of the AES, Port 5961, I see levels on the matrix, I can add it as NDI input in Vmix, but when I disconnect USB cable the audio disappears. I don't know what to do . Can you help me with the settings in order to have at least NDI input without USB cable? Thank you for your time.
I have run both in and out, but connected via the Ethernet port (POE) for NDI. That is, not using the USB port for anything.
