Bodo
#1 Posted : Tuesday, March 24, 2026 7:51:32 PM(UTC)
Bodo
Romania
Hello everyone,
I have tried to reduce the number of devices used for audio Master and BUS A for VmixCall.
The Magewell AES 67 is USB audio with a routing matrix that allows you use it for in and for out on different ways. I route 2 XLR balanced inputs from 2 mics to USB (as audio input in vmix) and BUS A from Vmix via USB to Analog outputs 2 XLR for 2 IEMs.
My problem is that this device doesn't refuses to work sometimes. One time is not giving output , other time is not routing input to VMIX. I have use it also with Zoom. Sometime it works sometime doesen't.
The advantage consist in the fact that you ca use One single device in one single USB port.
As system I use ASUS ROG i9 (new generation) Windows 10 ( more stable in my opinion), Vmix 4k up to date
Have someone tried Magewell AES 67? Have you had similar problems?
Do you know other similar device as AES 67 Magewell?
I have been in a bad situation during a live surgery transmission when suddenly the audio collapsed...
I appreciate any opinion.
Thank you.
richardgatarski
#2 Posted : Tuesday, March 24, 2026 8:41:11 PM(UTC)
richardgatarski
Never used mine via USB. Why do you not use it via ethernet and NDI instead?
Bodo
#3 Posted : Tuesday, March 24, 2026 9:22:48 PM(UTC)
Bodo
Romania
Never tried, but I will.
you can set Audio Bus A in NDI?
How does appear in the AES 67 matrix? As stream?
Thank you
Bodo
#4 Posted : Wednesday, March 25, 2026 3:47:31 AM(UTC)
Bodo
Romania
Richard,
Do you use one AES 67 both as in and out?
I have managet tu use in as NDI input in Vmix by enabling TX NDI Type unicast , IP of the AES, Port 5961,
I see levels on the matrix, I can add it as NDI input in Vmix, but when I disconnect USB cable the audio disappears. I don't know what to do .
Can you help me with the settings in order to have at least NDI input without USB cable?
Thank you for your time.
richardgatarski
#5 Posted : Thursday, March 26, 2026 10:38:11 PM(UTC)
richardgatarski
I have run both in and out, but connected via the Ethernet port (POE) for NDI. That is, not using the USB port for anything.
Roy Sinclair
#6 Posted : Thursday, May 7, 2026 6:37:13 AM(UTC)
Roy Sinclair
Was thanked: 31 time(s) in 27 post(s)
Originally Posted by: Bodo Go to Quoted Post
Hello everyone,
Thank you.
Make Sure you use the ASIO driver for the device on USB and not any other driver. vMix does not play well with the lesser drivers.
jet
#7 Posted : Thursday, May 7, 2026 11:29:20 AM(UTC)
jet
Was thanked: 24 time(s) in 22 post(s)
Hello everyone,
Thank you.
I would not trust on USB devices at all.
Tried Dante (network audio) and it seems to work great on a dedicated wired Dante network.
You probably need extra Dante enabled hardware like "Allen & Heath DT20" to get the best results.
Similar Topics
Improve USB audio interface persistence (Feature Requests)
by TBacker 10/14/2022 5:40:24 AM(UTC)
Bus A, B, C to USB Audio Interface (General Discussion)
by allklier 5/6/2022 10:03:57 PM(UTC)
Audient EVO 4 - USB audio interface (Hardware Compatibility)
by Monday Production 4/30/2021 2:46:58 AM(UTC)
USB audio interfaces with mix/minus capability (Hardware Compatibility)
by huggybear 11/29/2020 2:23:06 PM(UTC)
Tascam US-16x08 USB Audio Interface (Hardware Compatibility)
by DwFMagik 7/16/2020 8:41:27 AM(UTC)
Behringer X1204USB Audio interface / Mixer (3rd Party Software and Development)
by thargrove 3/24/2018 2:12:50 PM(UTC)
2 USB audio interfaces? (Hardware Compatibility)
by spencerm24 9/23/2017 2:45:12 PM(UTC)
