NDI
NDI Audio Capture only
Joined: 1/24/2018(UTC) Posts: 6 Location: Long Island, NY
Hi all,
I need a solution for audio capture. I currently use an 4 input mixer, connected to a laptop via USB to get different microphones into my streams. That mixer has died! So I'm looking at what to replace it with. I capture my video with Magewell NDI Capture devices. I was wondering if there is something similar for just audio capture? I've done some searches and haven't been able to find anything. Outside using Dante but I don't really want to use Dante. So I'm looking for suggestions and ideas. Any help would be appreciated!
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
I depends how much functionality you want to have on the audio IO side. Some suggestions. Motu has a lot of good IO devices. Behringer has some more cheaper options. From pure IO the "Flow 8" might be worth looking into. For more inputs look into XR18. Another idea for DSP/Dante included but connected via USB to vMix also look at Yealink AP08. Focusrite can also be an option in the IO area.
Originally Posted by: elvis55  Behringer UMC404HD Funny, this is what I'm looking to replace.
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
I'm slightly confused on what you're looking for. You mention NDI and Dante, so that leads me to believe you're looking for an audio over Ethernet type of solution. Is that the case? Or are you just looking for something to replace your broken audio interface, that connects via USB?
Originally Posted by: kross  I'm slightly confused on what you're looking for. You mention NDI and Dante, so that leads me to believe you're looking for an audio over Ethernet type of solution. Is that the case? Or are you just looking for something to replace your broken audio interface, that connects via USB? Definitely looking for something over IP. I was looking for something simple but the more I look it doesn't look like it exists. I wan't an NDI capture device that only does audio. I have Magewell Pro Connect NDI capture cards, they are great. I want something similar for Audio. I have 4 mics that I want to bring into vMix and do the mixing in vMix. I had a Behringer UMC404HD but I needed to connect that to my Laptop and it took up a USB port. I was hoping for something more IP based but without using Dante.
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Originally Posted by: waxxel  Definitely looking for something over IP. I was looking for something simple but the more I look it doesn't look like it exists. I wan't an NDI capture device that only does audio. I have Magewell Pro Connect NDI capture cards, they are great. I want something similar for Audio. I have 4 mics that I want to bring into vMix and do the mixing in vMix. I had a Behringer UMC404HD but I needed to connect that to my Laptop and it took up a USB port. I was hoping for something more IP based but without using Dante. Those Magewell Pro Connect are also USB, aren't they? Do you use them on a different computer and use NDI inputs on your vMix machine? There is a command line tool for ASIO to NDI. Haven't used it, but maybe you want to try this. You will need a audio capture device somewhere, though. https://ndi.video/tools/free-audio/
Originally Posted by: dmwkr  Originally Posted by: waxxel  Definitely looking for something over IP. I was looking for something simple but the more I look it doesn't look like it exists. I wan't an NDI capture device that only does audio. I have Magewell Pro Connect NDI capture cards, they are great. I want something similar for Audio. I have 4 mics that I want to bring into vMix and do the mixing in vMix. I had a Behringer UMC404HD but I needed to connect that to my Laptop and it took up a USB port. I was hoping for something more IP based but without using Dante. Those Magewell Pro Connect are also USB, aren't they? Do you use them on a different computer and use NDI inputs on your vMix machine? There is a command line tool for ASIO to NDI. Haven't used it, but maybe you want to try this. You will need a audio capture device somewhere, though. https://ndi.video/tools/free-audio/ You can get USB versions of Magewell capture cards but these are NDI only. So connect directly to your switch, bring directly into vMix with NDI. I've used the ASIO to NDI, but thank you for the suggestion.
For a 4ch Dante interface with preamps look into SYNQ DBT44. I use it in different setups. It's basically a matrix mixer with 4 analog IO and 4 Dante IO channels. https://synq-audio.com/de/dbt-44If you need to get just NDI audio take a look at the NDI tools page. At the buttom right you find a cmd line tool "Free Audio" that you can use from NDI directly. Also "Lama" does a good job in using NDI with up to 255 ch.
 1 user thanked mavik for this useful post.
Joined: 7/23/2013(UTC) Posts: 136  Location: North Thanks: 14 times Was thanked: 13 time(s) in 11 post(s)
Originally Posted by: mavik  For a 4ch Dante interface with preamps look into SYNQ DBT44. I use it in different setups. It's basically a matrix mixer with 4 analog IO and 4 Dante IO channels. https://synq-audio.com/de/dbt-44 Interesting product! Can you report how does the preamp works for typical dynamic microphones regarding sufficient gain? Does it need additional amplification with FetHead or similar? (Sorry for the quick branching off - there weren't detailed information in the datasheet.)
NDI
