waxxel
#1 Posted : Wednesday, January 14, 2026 6:16:25 AM(UTC)
waxxel
Hi all,
I need a solution for audio capture. I currently use an 4 input mixer, connected to a laptop via USB to get different microphones into my streams. That mixer has died! So I'm looking at what to replace it with. I capture my video with Magewell NDI Capture devices. I was wondering if there is something similar for just audio capture? I've done some searches and haven't been able to find anything. Outside using Dante but I don't really want to use Dante. So I'm looking for suggestions and ideas. Any help would be appreciated!
mavik
#2 Posted : Wednesday, January 14, 2026 6:38:40 PM(UTC)
mavik
I depends how much functionality you want to have on the audio IO side. Some suggestions.
Motu has a lot of good IO devices.
Behringer has some more cheaper options. From pure IO the "Flow 8" might be worth looking into. For more inputs look into XR18.
Another idea for DSP/Dante included but connected via USB to vMix also look at Yealink AP08.
Focusrite can also be an option in the IO area.
elvis55
#3 Posted : Wednesday, January 14, 2026 6:59:02 PM(UTC)
elvis55
Switzerland
Behringer UMC404HD
waxxel
#4 Posted : Thursday, January 15, 2026 12:06:16 AM(UTC)
waxxel
Originally Posted by: elvis55 Go to Quoted Post
Behringer UMC404HD
Funny, this is what I'm looking to replace.
kross
#5 Posted : Thursday, January 15, 2026 6:58:57 AM(UTC)
kross
Was thanked: 46 time(s) in 45 post(s)
I'm slightly confused on what you're looking for. You mention NDI and Dante, so that leads me to believe you're looking for an audio over Ethernet type of solution. Is that the case? Or are you just looking for something to replace your broken audio interface, that connects via USB?
waxxel
#6 Posted : Friday, January 16, 2026 1:08:50 AM(UTC)
waxxel
Definitely looking for something over IP. I was looking for something simple but the more I look it doesn't look like it exists. I wan't an NDI capture device that only does audio. I have Magewell Pro Connect NDI capture cards, they are great. I want something similar for Audio. I have 4 mics that I want to bring into vMix and do the mixing in vMix. I had a Behringer UMC404HD but I needed to connect that to my Laptop and it took up a USB port. I was hoping for something more IP based but without using Dante.
dmwkr
#7 Posted : Friday, January 16, 2026 2:15:25 AM(UTC)
dmwkr
Those Magewell Pro Connect are also USB, aren't they? Do you use them on a different computer and use NDI inputs on your vMix machine?
There is a command line tool for ASIO to NDI. Haven't used it, but maybe you want to try this. You will need a audio capture device somewhere, though.
https://ndi.video/tools/free-audio/
waxxel
#8 Posted : Sunday, January 18, 2026 6:04:59 AM(UTC)
waxxel
You can get USB versions of Magewell capture cards but these are NDI only. So connect directly to your switch, bring directly into vMix with NDI. I've used the ASIO to NDI, but thank you for the suggestion.
mavik
#9 Posted : Monday, January 19, 2026 8:06:25 AM(UTC)
mavik
For a 4ch Dante interface with preamps look into SYNQ DBT44. I use it in different setups. It's basically a matrix mixer with 4 analog IO and 4 Dante IO channels.
https://synq-audio.com/de/dbt-44
If you need to get just NDI audio take a look at the NDI tools page. At the buttom right you find a cmd line tool "Free Audio" that you can use from NDI directly. Also "Lama" does a good job in using NDI with up to 255 ch.
jip on 1/26/2026(UTC)
jip
#10 Posted : Monday, January 26, 2026 3:16:18 AM(UTC)
jip
Estonia
Interesting product!
Can you report how does the preamp works for typical dynamic microphones regarding sufficient gain? Does it need additional amplification with FetHead or similar?
(Sorry for the quick branching off - there weren't detailed information in the datasheet.)
