jpeg2RAW
#1 Posted : Monday, September 8, 2014 8:57:22 PM(UTC)
jpeg2RAW
Been doing some more testing and have a few more questions:
I am thinking of using MPEG-2 for the local file recording. With Wirecast, I have always used x.264 because that was the profile use to stream. Using MPEG-2 results in a MUCH larger file and since our show normally last about 1 hours and can have as much as 1 more hour (total 2 hours) of pre & post show discussions, the file is going to be HUGE. A 30 minute recording I did as a test resulted in a 2GB file. Assuming the same holds true for the 2 hours, I would end up with a 8GB file.
1. How often do split the file during recording? Any issues with bringing these together later, like a noticeable skip?
2. Wirecast files caused audio/video sync issues if edited in Adobe Premiere Pro due to the variable frame rate, which may be more of a Adobe issue. Does using the TS name vs the MPG name make any difference? I know it says TS is better for editing, but how is it better?
3. Should I even be using MPEG-2 for the local file recording?
#2 Posted : Tuesday, September 9, 2014 3:35:06 PM(UTC)
@ jpeg2RAW
Which version of Premiere Pro are you running?
You might gleen some insight from this thread:
http://forums.vmix.com.a....aspx?g=posts&t=2667
So far I have had good results recording .TS and renaming to .MPG...
jpeg2RAW
#3 Posted : Tuesday, September 9, 2014 10:00:45 PM(UTC)
jpeg2RAW
I am running the latest version of Premiere Pro which I think is CC2014.
jpeg2RAW
#4 Posted : Tuesday, September 9, 2014 10:17:10 PM(UTC)
jpeg2RAW
I just tested the file splitting thing. Playing music and had the file split every 5 minutes. At the split, you can tell a very slight change, but it is so slight I can't imagine it would be an issue in a podcast with people talking.
jpeg2RAW
#5 Posted : Wednesday, September 10, 2014 7:11:30 PM(UTC)
jpeg2RAW
I am going to test this myself, but I would love to hear from someone who has done this a good bit already. If I have about a 2 hour recording time, record in MPEG-2 and have a new file created every 30 minutes, is the results dependable? Meaning, no issues with the split and I don't end up with one of the 4 files being corrupt? Of course if I had everything in one file and it was corrupt then I would have nothing, but the show is pretty much lost if 1 of the 4 files is corrupt also. Corrupt files is not something I have a lot, in fact, in all my Wirecast broadcast, I have never had a single corrupt file. Guess I am just a bit paranoid about the program creating new files during the broadcast that I need to splice together later.
#6 Posted : Thursday, September 11, 2014 3:19:18 AM(UTC)
Was thanked: 4726 time(s) in 1618 post(s)
Splitting MPEG-2 files is not necessary, as the files can be recovered if the system crashes.
The only formats that cannot be recovered after a crash are AVI and MP4.
Similar Topics
Lost recorded files (General Discussion)
by videokommando 9/6/2021 9:17:07 PM(UTC)
Recommended optimization of pre recorded files for smooth playback in vMix? (General Discussion)
by coskel22 7/12/2016 8:32:31 PM(UTC)
Help with avi recorded files (General Discussion)
by ClementN 12/16/2014 1:02:22 AM(UTC)
Multicorder Timecode for recorded files (General Discussion)
by wiseguy 4/23/2012 11:50:20 AM(UTC)
