52 Pages«<49505152>
raugert
#1001 Posted : Thursday, February 13, 2025 5:25:20 AM(UTC)
raugert
Canada
Originally Posted by: Luis70 Go to Quoted Post
The link not working, it does not launch at all
The links in the first post of this thread are working... They should redirect you to a dropbox download..
Are you using a link from elsewhere ?
dmwkr
#1002 Posted : Thursday, May 22, 2025 5:37:02 PM(UTC)
dmwkr
Originally Posted by: raugert Go to Quoted Post
UPDATE: Version 4.0.62
Change log:
BitFocus buttons are now compatible with new format intoduced inBitFocus3.3(Page,Row,Column) --use Bitfocus version 3.4.0 Beta for compatibility
Hi Richard,
I was just testing out the BitFocus buttons feature. Could it be that the iOS Panel Builder app does not support this new format (Page, Row, Column) yet? Or am I missing something? The buttons are working fine on Mac OS, but not on iOS.
Thank you!
raugert
#1003 Posted : Thursday, May 22, 2025 10:02:27 PM(UTC)
raugert
Canada
Thanks for the report dmwkr. As far as I remember it should work but I will look into it...
Richard
thanks 1 user thanked raugert for this useful post.
mairginter@hotmail.com on 11/12/2025(UTC)
#1004 Posted : Sunday, November 9, 2025 4:34:38 AM(UTC)
Italy
Future and further development of Panel Builder
Hi @raugert,
Thank you very much for the tool, it's really great. I use it for all our live events. I definitely find it better than hardware keys. This is mainly because the flexible layout and numerous functions make it much easier to keep track of everything and find the right button much faster and more reliably.
As always, I'm revising, expanding, and improving our setup. I wanted to ask you if you're still actively supporting and expanding the project. With the release of vMix 29, a few new shortcuts have been added. Of course, we want to take advantage of them. Can you tell me if you plan to expand the Panel Builder in this regard?
As I asked you last year, I also recommended the Panel Builder to a few colleagues who mainly work with Companion and Black Magic switchers. They were also very enthusiastic.
It would be really great if you could integrate the Panel Builder as a surface in Companion and display the button texts. The ScreenDeck tool does something similar. It would be really great if I could add an entire page from “Companion.” Or if, after selecting a page, I could simply drag the buttons onto the panel and distribute them there, just like all the other buttons.
Maybe you could use parts of the ScreenDeck project if the developer agrees.
josephdadams/screendeck
Even if you no longer work on Panel Builder—which I would find really unfortunate—I would like to thank you again for your work so far!
Luis70
#1005 Posted : Sunday, November 9, 2025 5:12:33 AM(UTC)
Luis70
Grenada
I also wish he could make it for tablets as an app, and use it directly from there to trigger buttons on a pc, similar to an earlier app that I had used ....think it was called 'Virtual Control Surface', and it was made by a vmix user called Seth Haberman (Cloud Media Group)...it was designed to be an app to run on tablets to control vmix...worked great, but came with too many input buttons that were not being used, and could not be user re-ordered, as in Panel Builder....I think Panel Builder is the Best thing that happened to vmix...its user friendly, user designed, and I even done my own layout and designs for the buttons...see attachments....and these are simple ones... and where the 'Virtual Control Surface' is limited to 12 inputs, with Panel Builder can have as much inputs as vmix will allow only thing, I don't think they make laptops with that much space to hold all those buttons, but you can setup Panel builder with many pages, each page containing as much buttons as you the user want to set...as in my attachments, I have Video, and Audio
Screen Capture.jpg (3,012kb) downloaded 55 time(s).
Screenshot 2025-11-08 pb 1.png (143kb) downloaded 433 time(s).
Screenshot 2025-11-08 pPB.jpg (115kb) downloaded 433 time(s).
link to the video where he spoke to Tom Sinclair of StreamingIdoits...2019
Ballen
#1006 Posted : Tuesday, November 18, 2025 5:24:59 PM(UTC)
Ballen
Sweden
After updating to vMix29 I encountered a problem with vMix Panel Builder.
"xmlerr, can't find element".
Does anyone else have this issue?
Luis70
#1007 Posted : Tuesday, November 18, 2025 9:38:50 PM(UTC)
Luis70
Grenada
If you had change your default directory, like I did, you will have to change it back to the default, which is on the 'C' drive...(C:/Users/YOUR NAME/Documents/vMix Panel Builder), then check to make sure that you have the vMix IP is 127.0.0.1...that may be your issue...just check
Ballen
#1008 Posted : Tuesday, November 18, 2025 11:59:16 PM(UTC)
Ballen
Sweden
I have connection towards vmix and the commands work its just that I cant add new ones and no tallys work.
Im using default directories and I havent changed anything.
I got the response in an email that they are looking at it.
Luis70
#1009 Posted : Wednesday, November 19, 2025 12:12:51 PM(UTC)
Luis70
Grenada
By the way, are you on windows 10 or windows 11....I found out for myself that updating to windows is causing issues.....I am now giving windows 10 Enterprise LTSC a test, and so far, ... no issues...runs much better than standard windows 10 pro, and windows 11
#1010 Posted : Thursday, November 27, 2025 5:28:51 AM(UTC)
Italy
Does anyone know if Richard plans to continue developing Panel Builder and if there are plans to add the new shortcuts from vmix 29 in the near future?
Greetings to all Panel Builder users
raugert
#1011 Posted : Thursday, November 27, 2025 5:53:12 AM(UTC)
raugert
Canada
Yes, I am currently working on an update :)
Richard
mairginter@hotmail.com on 11/27/2025(UTC)
raugert
#1012 Posted : Friday, December 12, 2025 4:17:56 AM(UTC)
raugert
Canada
Here is the latest version:
ChangeLog:
- fixed TextAsInput not working correctly when using DataSource in command
- fixed "SetPosition" not working correctly when Input name contains a space
- added New shortcuts for vMix29
- added "Alternate IP" field in InfoBox (Can be used to send commands to an alternate vMix computer. Note: There is no tally feedback when using this feature)
https://cli.re/vMix-Panel-Builder-4.0.64
thanks 3 users thanked raugert for this useful post.
MickeyMJJ on 12/12/2025(UTC), dmwkr on 12/12/2025(UTC), Luis70 on 12/12/2025(UTC)
Luis70
#1013 Posted : Friday, December 12, 2025 11:33:12 PM(UTC)
Luis70
Grenada
Great, works flawless so far .... keep the updates and improvements coming...we really appriciate it.... best thing that happened to vMix from 3rd party suppliers
Luis70 say so...
TL68
#1014 Posted : Monday, January 5, 2026 11:41:52 PM(UTC)
TL68
Sweden
Hi!
Trying to read up on this software. Looks really interesting!
I see some kind of support for Bitfocus Buttons mentioned in a release note but I fail to find further information about this integration.
I would appreciate if someone could share this or point to a post or video describing it.
Thanks! /T
raugert
#1015 Posted : Tuesday, January 6, 2026 2:17:28 AM(UTC)
raugert
Canada
Originally Posted by: TL68 Go to Quoted Post
Hi!
Thanks! /T
Basically, you can trigger a BitFocus Button from a button within the Panel Builder app. Simply enter the BitFocus (Page,Row,Column) in the appropriate fields of the button. You also need to add the BitFocus IP in the Panel Builder Preferences for it to work. (this is the IP of the computer running the BitFocus app)
There has been some progress with BitFocus integration but I haven't updated the User guide for some time. I will get to that soon.
Richard
TL68 on 1/7/2026(UTC)
nilknarf78
#1016 Posted : Monday, January 19, 2026 8:17:41 AM(UTC)
nilknarf78
After upgrading to the latest versions of both vMix and vMPB, I'm seeing a huge performance hit in the responsiveness of vMPB. When I press a button, the actual vMix response is still pretty quick, but the tally response can take a second or more. For audio faders, the fader is slow to move in vMPB and the attached VU meter is choppy. I've noticed this in 4.0.62 and 4.064.
I rolled back to 4.042, as that's the last known good version I have, and it still works fine.
My vMix version is 29.0.0.44.
I'm running on Windows 10 Pro. Upgrading any of the computers to Windows 11 is not an option at the moment. However, I have access to a W11Pro computer I should be able to put on the network and test with to see if that's the issue, but probably not until next weekend.
I also noticed the current version renders the controls slightly different than the older versions. That's more of an annoyance, and it's a one-time adjustment to the template to compensate for.
raugert
#1017 Posted : Tuesday, January 20, 2026 1:59:27 AM(UTC)
raugert
Canada
There should be no response issues with Window 10 Pro and VMPB 4.0.64. VMPB 4.0.42 is at least 3 years old and many updates have been made since then. If you made your template with version 4.0.42 then it's probably a compatibility issue with the newer versions.
Try creating a new template with the latest version 4.0.64 to see if you still have slow tally response. That would help rule out Win10 or possible network issues.
thanks,
Richard
#1018 Posted : Tuesday, January 27, 2026 11:24:10 PM(UTC)
Italy
Question about a minor problem/bug:
Since the latest Companion updates, I've been having problems with feedback, meaning that keystrokes are being transmitted to Companion, but the feedback in the form of key coloring is no longer working.
I've tried the last three versions of Panel Builder and have the same problem with all of them.
Can anyone confirm this, or is the problem possibly just with my installation?
I am addressing companion via 127.0.0.1
Regards Alex
raugert
#1019 Posted : Tuesday, January 27, 2026 11:46:02 PM(UTC)
raugert
Canada
Regards Alex
Make sure you program the "feedback reset" in Bitfocus Companion button 1/3/0. I've updated the User manual to show how to do that.
#1020 Posted : Wednesday, January 28, 2026 1:45:35 AM(UTC)
Italy
Regards Alex
Thanks for the quick response. I had already read about the reset and tested it. Just so I don't misunderstand, by device connection, you mean the plugin that provides the feedback. In my case, that's “generic OSC,” which I use to control the virtual production software aximmetry, and unfortunately, the reset or deactivation/activation didn't work here.
Guest (18)
52 Pages«<49505152>
