Joined: 11/27/2023(UTC) Posts: 136  Thanks: 10 times Was thanked: 10 time(s) in 10 post(s)
I have just discovered that the API function to toggle on and off Audio Buses on the output do not work in vMix 28.. The Master works ... is there a way to fix this
Joined: 1/25/2019(UTC) Posts: 334  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
Originally Posted by: Peter1000  I found that page, and I tried using the commands and it does Not work in Version 28. It does not work...tried it over and over with the same results
Take a deep breath... Can you describe what you did or what exactly you want to do? Do you have at least a 4K version? The other versions do not support scripting. It's best to copy your script here as a reply . put the code between <code> ..... </code>
Joined: 11/23/2020(UTC) Posts: 251  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: Peter1000  Take a deep breath... Can you describe what you did or what exactly you want to do? Do you have at least a 4K version? The other versions do not support scripting. It's best to copy your script here as a reply . put the code between <code> ..... </code> Turning buses off and on here using scripts since vMix version 22. <input variable name>.Function("AudioBusOff","M") <---- "M" indicating Master bus, "A" through "G" for the rest of the buses.
Originally Posted by: Roy Sinclair  Originally Posted by: Peter1000  Take a deep breath... Can you describe what you did or what exactly you want to do? Do you have at least a 4K version? The other versions do not support scripting. It's best to copy your script here as a reply . put the code between <code> ..... </code> Turning buses off and on here using scripts since vMix version 22. <input variable name>.Function("AudioBusOff","M") <---- "M" indicating Master bus, "A" through "G" for the rest of the buses. Function=MasterAudioOn Function=BusBAudioOn Function=BusAAudioOn This is the code I am using The Master works, but not the Buses
this should work, try this in script , it switches all audio busses on Code:Dim busValues As String() = {"A", "B", "C", "D", "E", "F", "G"}
For Each value As String In busValues
API.Function("BusXAudioOn", Value:=value)
Next
it switches all audio busses off Code:Dim busValues As String() = {"A", "B", "C", "D", "E", "F", "G"}
API.Function("BusXAudioOff", Value:=value)
Next
it toggles all audio busses Code:Dim busValues As String() = {"A", "B", "C", "D", "E", "F", "G"}
API.Function("BusXAudio", Value:=value)
Next
For the Master you have to use or toggle
Function=SetColor&Input=ColorPlaceholder.gtzip&Value=#80FF00&SelectedName=Color1.Fill.Color&Duration=5000 Function=Cut&input=BLACK&Duration=1000 Sleep 2000 Function=MasterAudioOn Function=BusAAudioOn Function=BusBAudioOn Function=SetMasterVolume&Duration=4000&Value=85 Function=SetBusAVolume&Duration=4000&Value=85 Function=SetBusBVolume&Duration=4000&Value=85 Function=AudioOn&Input=NATIONAL ANTHEM Function=AudioOn&Input=PLAYER 1 Function=AudioOn&Input=PLAYER 2 Function=AudioOn&Input=PLAYER 3 Function=Restart&Input=BACKGROUND MUSIC Function=Play&Input=BACKGROUND MUSIC Function=SetVolumeFade&Input=BACKGROUND MUSIC&Value=85,5000 Function=AudioOn&Input=BACKGROUND MUSIC&Duration=500 Function=AudioOn&Input=HYMNS&Duration=500 Function=AudioOn&Input=Audio Microphone Function=SetVolumeFade&Input=USB AUDIO&Value=85,6000 Function=SetVolumeFade&Input=Audio Digital Audio Interface&Value=85,6000 Function=SetVolumeFade&Input=Audio Digital Audio Interface usb 3&Value=85,6000 Function=SetVolumeFade&Input=HYMNS&Value=85,6000 Function=SetVolumeFade&Input=PLAYER 1&Value=85,4000 Function=SetVolumeFade&Input=PLAYER 2&Value=85,4000 Function=SetVolumeFade&Input=PLAYER 3&Value=85,4000 Function=Play&Input=SLATE Function=Fade&Input=SLATE&Duration=5000&Mix=0 Function=SetVolumeFade&Input=CAM 1&Value=85,6000 Function=SetVolumeFade&Input=CAM 2&Value=85,6000 Function=SetVolumeFade&Input=CAM 3&Value=85,6000 Function=SetVolumeFade&Input=CAM 4&Value=85,6000 Function=SetVolumeFade&Input=Audio Microphone&Value=85,6000 Function=SetColor&Input=ColorPlaceholder.gtzip&Value=#FFFFFF&SelectedName=Color1.Fill.Color
...This is what my code looks like....it worked perfect with vmix 26, but does not work with vmix 28...the "ON" does not work with any of the buses, only the master. When I trigger the code for FTB, it works perfect, everything switches 'Off', but when I run this code the 'Buses' do not turn 'On', they remain 'Off'
I copied your code into a new script in my vMix 29.36 in an empty project (new, no inputs). I manually turned off all audio buses and then ran your script. Master and buses A and B turned on perfectly. I would test that on another computer.
Originally Posted by: Peter1000  I copied your code into a new script in my vMix 29.36 in an empty project (new, no inputs). I manually turned off all audio buses and then ran your script. Master and buses A and B turned on perfectly. I would test that on another computer. You proberly did not read my mesdsage correctly....I said vmix 28.0.0.42....It works in vmix 29, but I have other PCs that I work with that still have vmix 28
same on a older I7 machine, vMix 28.36, i manually turned off all audio buses and then added your full command list to a new script. Master and buses A and B turned on perfectly. Fortunately, there are options...
Originally Posted by: Peter1000  same on a older I7 machine, vMix 28.36, i manually turned off all audio buses and then added your full command list to a new script. Master and buses A and B turned on perfectly. Fortunately, there are options... you still haven't read my message correctly:..I said 28.0.0.42
Rank:: Administration
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
I can confirm both these functions definitely work in 28.42: Function=BusBAudioOn Function=BusAAudioOn
Originally Posted by: admin  I can confirm both these functions definitely work in 28.42: Function=BusBAudioOn Function=BusAAudioOn
Then it must be a windows 11 issue
