Luis70
#1 Posted : Friday, October 31, 2025 3:47:56 AM(UTC)
Luis70
Grenada
I have just discovered that the API function to toggle on and off Audio Buses on the output do not work in vMix 28.. The Master works ... is there a way to fix this
Peter1000
#2 Posted : Friday, October 31, 2025 5:13:03 AM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
find all commands here
Unofficial vMix API Reference
Luis70
#3 Posted : Friday, October 31, 2025 8:33:33 AM(UTC)
Luis70
Grenada
I found that page, and I tried using the commands and it does Not work in Version 28. It does not work...tried it over and over with the same results
Peter1000
#4 Posted : Saturday, November 1, 2025 1:46:38 AM(UTC)
Peter1000
Switzerland
Take a deep breath... Can you describe what you did or what exactly you want to do? Do you have at least a 4K version? The other versions do not support scripting. It's best to copy your script here as a reply . put the code between
<code>
</code>
Roy Sinclair
#5 Posted : Thursday, November 6, 2025 7:05:10 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
<code>
</code>
Turning buses off and on here using scripts since vMix version 22. <input variable name>.Function("AudioBusOff","M") <---- "M" indicating Master bus, "A" through "G" for the rest of the buses.
Luis70
#6 Posted : Thursday, November 6, 2025 7:25:19 AM(UTC)
Luis70
Grenada
<code>
</code>
Function=MasterAudioOn
Function=BusBAudioOn
Function=BusAAudioOn
This is the code I am using The Master works, but not the Buses
Peter1000
#7 Posted : Saturday, November 8, 2025 5:55:17 AM(UTC)
Peter1000
Switzerland
this should work, try this in script , it switches all audio busses on
Code:
Dim busValues As String() = {"A", "B", "C", "D", "E", "F", "G"}
For Each value As String In busValues
    API.Function("BusXAudioOn", Value:=value)
Next
it switches all audio busses off
Code:
    API.Function("BusXAudioOff", Value:=value)
Next
it toggles all audio busses
Code:
    API.Function("BusXAudio", Value:=value)
Next
For the Master you have to use
Code:
MasterAudioOn
Code:
MasterAudioOff
or toggle
Code:
MasterAudio
Luis70
#8 Posted : Saturday, November 8, 2025 2:07:20 PM(UTC)
Luis70
Grenada
Function=SetColor&Input=ColorPlaceholder.gtzip&Value=#80FF00&SelectedName=Color1.Fill.Color&Duration=5000
Function=Cut&input=BLACK&Duration=1000
Sleep 2000
Function=SetMasterVolume&Duration=4000&Value=85
Function=SetBusAVolume&Duration=4000&Value=85
Function=SetBusBVolume&Duration=4000&Value=85
Function=AudioOn&Input=NATIONAL ANTHEM
Function=AudioOn&Input=PLAYER 1
Function=AudioOn&Input=PLAYER 2
Function=AudioOn&Input=PLAYER 3
Function=Restart&Input=BACKGROUND MUSIC
Function=Play&Input=BACKGROUND MUSIC
Function=SetVolumeFade&Input=BACKGROUND MUSIC&Value=85,5000
Function=AudioOn&Input=BACKGROUND MUSIC&Duration=500
Function=AudioOn&Input=HYMNS&Duration=500
Function=AudioOn&Input=Audio Microphone
Function=SetVolumeFade&Input=USB AUDIO&Value=85,6000
Function=SetVolumeFade&Input=Audio Digital Audio Interface&Value=85,6000
Function=SetVolumeFade&Input=Audio Digital Audio Interface usb 3&Value=85,6000
Function=SetVolumeFade&Input=HYMNS&Value=85,6000
Function=SetVolumeFade&Input=PLAYER 1&Value=85,4000
Function=SetVolumeFade&Input=PLAYER 2&Value=85,4000
Function=SetVolumeFade&Input=PLAYER 3&Value=85,4000
Function=Play&Input=SLATE
Function=Fade&Input=SLATE&Duration=5000&Mix=0
Function=SetVolumeFade&Input=CAM 1&Value=85,6000
Function=SetVolumeFade&Input=CAM 2&Value=85,6000
Function=SetVolumeFade&Input=CAM 3&Value=85,6000
Function=SetVolumeFade&Input=CAM 4&Value=85,6000
Function=SetVolumeFade&Input=Audio Microphone&Value=85,6000
Function=SetColor&Input=ColorPlaceholder.gtzip&Value=#FFFFFF&SelectedName=Color1.Fill.Color
...This is what my code looks like....it worked perfect with vmix 26, but does not work with vmix 28...the "ON" does not work with any of the buses, only the master. When I trigger the code for FTB, it works perfect, everything switches 'Off', but when I run this code the 'Buses' do not turn 'On', they remain 'Off'
Peter1000
#9 Posted : Saturday, November 8, 2025 4:45:59 PM(UTC)
Peter1000
Switzerland
I copied your code into a new script in my vMix 29.36 in an empty project (new, no inputs).
I manually turned off all audio buses and then ran your script. Master and buses A and B turned on perfectly.
I would test that on another computer.
Luis70
#10 Posted : Saturday, November 8, 2025 9:06:22 PM(UTC)
Luis70
Grenada
You proberly did not read my mesdsage correctly....I said vmix 28.0.0.42....It works in vmix 29, but I have other PCs that I work with that still have vmix 28
Peter1000
#11 Posted : Sunday, November 9, 2025 7:51:50 AM(UTC)
Peter1000
Switzerland
same on a older I7 machine, vMix 28.36,
i manually turned off all audio buses and then added your full command list to a new script. Master and buses A and B turned on perfectly.
Fortunately, there are options...
Luis70
#12 Posted : Sunday, November 9, 2025 10:15:31 AM(UTC)
Luis70
Grenada
you still haven't read my message correctly:..I said 28.0.0.42
#13 Posted : Sunday, November 9, 2025 12:22:15 PM(UTC)
I can confirm both these functions definitely work in 28.42:
Luis70
#14 Posted : Sunday, November 9, 2025 6:30:36 PM(UTC)
Luis70
Grenada
Then it must be a windows 11 issue
#15 Posted : Sunday, November 9, 2025 8:10:47 PM(UTC)
That's not really possible.
Please inform the user to contact vMix support directly to diagnose further:
https://www.vmix.com/contact-us.aspx
Luis70 on 11/9/2025(UTC)
Guest (5)
Similar Topics
API function to set SRT output settings (Feature Requests)
by connor-be 10/15/2026 8:38:28 AM(UTC)
vMIx api function not working (General Discussion)
by Olesk 12/21/2023 5:20:50 AM(UTC)
Add API function for enabling/disabling input effects like the Chroma-Key (Feature Requests)
by engelschall 8/27/2022 8:40:11 AM(UTC)
VirtualSet "Visible" vs Layer Enable/Disable and API Function? (General Discussion)
by engelschall 7/14/2022 5:25:25 PM(UTC)
vMix Call API functions (Feature Requests)
by bacu89 1/7/2021 5:46:12 PM(UTC)
All vMix API functions (General Discussion)
by gilar 8/24/2020 11:39:28 AM(UTC)
API Function list typo: SelectName vs SelectedName (3rd Party Software and Development)
by stigaard 1/17/2020 11:48:29 PM(UTC)
http API function question (3rd Party Software and Development)
by HWL1223 8/6/2019 6:04:15 AM(UTC)
API function Start streaming (3rd Party Software and Development)
by it-rttv 3/29/2019 9:28:19 PM(UTC)
API function SEt Name of Input (3rd Party Software and Development)
by zenon 10/17/2015 4:58:24 AM(UTC)
API function - Shuffle list items (3rd Party Software and Development)
by stigaard 10/3/2015 3:58:40 PM(UTC)
More API functions (Feature Requests)
by daniel514 1/27/2015 4:12:12 PM(UTC)
API function to set a specified image I a photos input (General Discussion)
by Gozzi.dk 4/6/2014 4:52:25 AM(UTC)
by guztavo 8/26/2012 2:50:02 PM(UTC)
