Hardware Compatibility
hardware encoding with nvidia 5070
Using a new high end HP PC with Nvidia 5070. Streaming setup message said to untick hardware encode. Hardware encode always worked with my 12 year Dell. Any Ideas what to do. Client is PO'd due to extensive audio glitches.
Joined: 10/20/2023(UTC) Posts: 166  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
Originally Posted by: Tim@tbenedict.com  Using a new high end HP PC with Nvidia 5070. Enter the unspecified HP PC BIOS, and enable ReBAR - against other advice, it's to be located not on the GPU BIOS config (there is none accessible on the high end HP PCs), see the PCI slot config. Once done so, after a restart, the vMIX Settings -> Performance will show the Graphics Adapter GPU _with_ ReBAR enabled.
