                This has been asked a few times in the past, but never answered directly. Besides using a translator like Central Control, what is the trick to setting up a BCF2000 to control faders etc. in vMix?
  My controller is recognized, both in Shortcuts and Activators, and I can "Find" the faders/encoders when I create a new shortcut, but no vMix faders move when I move the physical faders, and the physical faders immediately drop to zero.
  I saw the same behavior when using this controller on an ATEM, but that issue turned out to be the USB dongles. When I used a CalDigit, a proper breakout unit, it worked just fine. For vMix I'm plugged directly into the tower.
  Thanks in advance if anyone has any insights here.
 Joined: 6/23/2019(UTC) Posts: 3   Location: Leipzig Was thanked: 1 time(s) in 1 post(s)
                I came across your post while searching. Have you found a solution yet? I have the same problem. Many people say it works, but no one tells you how.
                Hi. Yes, I did work out a solution for this. Once I get a chance to set it up again, I’ll get back to you with what I learned. Don’t remember off the top of my head. :-)
