cpaustin2000
#1 Posted : Friday, July 4, 2025 2:35:57 AM(UTC)
cpaustin2000
Hello Team,
I’d like to suggest a simple but valuable feature: a built-in audio limiter for the master output. The goal is to prevent clipping or distortion during streaming or recording. Nothing overly complex—just a checkbox option that enables vMix to automatically protect the master audio from peaking beyond safe levels.
This would be a great addition for users who need reliable, clean audio without extra setup or third-party tools.
Thank you for your continued innovation and support.
Best regards,
Carlos in Texas
mavik
#2 Posted : Friday, July 4, 2025 3:20:38 PM(UTC)
mavik
You know that you can load VST plugins into vMix.
marton
#3 Posted : Friday, July 4, 2025 10:11:12 PM(UTC)
marton
Yes, it's not a bad idea. VST is possible but limiter is same important as compressor or noise gate which are implemented natively.
cpaustin2000
#4 Posted : Saturday, July 5, 2025 5:43:33 AM(UTC)
cpaustin2000
Yes I do. Danke. carlos
WaltG12
#5 Posted : Saturday, July 5, 2025 5:55:04 AM(UTC)
WaltG12
+1
The chain in vMix puts VSTs before pretty much everything.
A limiter, for obvious reasons, should be the last thing in the chain, not among the first.
This is why I recommend leaving pretty much everything built-in untouched and only using VSTs, so you can build your own chain and put a limiter at the end of it.
Otherwise, using the built-in compressor or gain/AGC control will render a VST limiter useless.
cpaustin2000
#6 Posted : Monday, July 7, 2025 4:23:56 AM(UTC)
cpaustin2000
I agree Walt. Carlos
