Feature Requests
Feature Request: Built-In Audio Limiter for Master Output
Joined: 1/14/2021(UTC) Posts: 16   Location: Austin Thanks: 2 times
Hello Team,
I’d like to suggest a simple but valuable feature: a built-in audio limiter for the master output. The goal is to prevent clipping or distortion during streaming or recording. Nothing overly complex—just a checkbox option that enables vMix to automatically protect the master audio from peaking beyond safe levels.
This would be a great addition for users who need reliable, clean audio without extra setup or third-party tools.
Thank you for your continued innovation and support.
Best regards, Carlos in Texas
You know that you can load VST plugins into vMix.
Yes, it's not a bad idea. VST is possible but limiter is same important as compressor or noise gate which are implemented natively.
Originally Posted by: marton  Yes, it's not a bad idea. VST is possible but limiter is same important as compressor or noise gate which are implemented natively. Yes I do. Danke. carlos
Joined: 7/4/2021(UTC) Posts: 408  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
+1 Originally Posted by: mavik  You know that you can load VST plugins into vMix. The chain in vMix puts VSTs before pretty much everything.A limiter, for obvious reasons, should be the last thing in the chain, not among the first. This is why I recommend leaving pretty much everything built-in untouched and only using VSTs, so you can build your own chain and put a limiter at the end of it. Otherwise, using the built-in compressor or gain/AGC control will render a VST limiter useless.
Feature Requests
