anderson
#1 Posted : Sunday, August 31, 2014 2:10:03 PM(UTC)
anderson
Hello
First post, newbie to Vmix and streaming so forgive if questions are basic.
My system specs:
Intel i7-4770 @ 3.4ghz
Windows 8.1 64 bit
8gb RAM
Nvidia GeForce GT635 w/2gb memory
Capture device - Blackmagic intensity pro
Running latest vMix (13.0.0.142)
Installed flash media live encoder (FMLE) 3.2
I've installed all the latest drivers for graphic and capture card
My issue:
Scenario - I open vMix preset with Blackmagic (camera) as input one and a preproduced video as input 2. I click "stream".
Then I open FMLE. All looks good up to this point
After a few minutes of streaming, the "camera" input locks up. I close vMix and computer blue screens on me (bsod).
Happens consistently and every time.
Any suggestions would be greatly appreciated.
Cheers, Jeff
#2 Posted : Sunday, August 31, 2014 8:44:11 PM(UTC)
@ anderson
You may have to "isolate" the problem through a process of elimination, but it sounds like a capture card conflict somewhere.
What are all your settings in the chain (inputs through to intensity pro settings, vMix settings and FMLE settings)?
Was this found in preliminary testing or a relatively new "issue" in your streaming experience? (any hardware or software additions since you last streamed etc.)
Are there any error messages or can you look at the log file?
How does vMix behave without streaming?
With just video input?
With just camera input?
Can you stream anything (videos or a web cam) from vMix for more than a few minutes?
When you say "the 'camera' input locks up" what does that mean?
Is vMix operational otherwise?
Have you tried to "reset" the input prior to shutting down?
Have you monitored your CPU cores and memory with Task Manager?
Is one or more cores maxing out?
I know it can be very frustrating when things don't work as they should, and your specs look pretty good but something is not keeping up somewhere in the chain, so the more info you can relay, the better able the community will be at helping you solve your issue.
anderson on 9/1/2014(UTC)
#3 Posted : Sunday, August 31, 2014 9:15:22 PM(UTC)
One thing to keep in mind, blue screen errors can only be caused by either faulty drivers or faulty hardware.
This means the intensity card may be faulty or not compatible with your system unfortunately.
Try updating to the latest intensity pro drivers, if that doesn't work try installing it into a different slot on the motherboard.
There is also a smaller chance of faulty memory. This is harder to diagnose, but it usually results
in "random" behaviour such as random blue screen errors or unexplainable error messages in vMix.
http://windows.microsoft...roblems-on-your-computer
anderson
#4 Posted : Monday, September 1, 2014 12:33:13 AM(UTC)
anderson
Thanks for the response. When the system gives me a BSOD, I get the message PFN_LIST_CORRUPT
Here's my settings as best as I can provide:
First, in the BLACKMAGIC DESIGN CONTROL PANEL -
Set Output: HDMI & composite & s-video
Set input: Composite Video (y in) & analog RCA audio (I am running a composite SD signal)
Set default video standard as: NTSC (I'm in the states)
Select output processing: off
Select input processing: off
Next, FMLE -
Preset: Medium bandwidth (300kbps) - VP6
Video and Audio boxes ticked
VIDEO
Device: Blackmagic WDM capture
Format: VP6
Frame rate: 30
Input size: 720 x 480 (maintain aspect ratio)
Bit Rate: 200 kbps Output size 320 x 240
AUDIO
Device: vMix audio
Format: Mp3
Channels: mono
Sample rate: 22050 hz
Bit rate: 48 kbps
-Total video 1 + audio bit rate: 248 kbps
-Total bandwidth required to stream: 248 kbps
PANEL OPTIONS
Panel options: output
FMS URL: (from Ustream account)
Backup url: none
Stream: (From Ustream account)
Device: vMix Audio
Format: Mp3
Channels:
VMIX SETTINGS-
Not sure specifically what vMix settings would be most helpful for you to look at. I'll start with "settings" in upper right of GUI.
Display - Theme: charcoal8
Master frame rate: NTSC 29.7p
Output size: 640 x 480
Output screen: 2
Output position: all zeros
Preview size: auto
Input size: 208 x 156
Rows: 1
Outputs: Output............Output
-all checked-
Options: Language: english
Start in advance mode
Start maximised
Display confirmation for record, external, stream, and multi view buttons
Automatically pause preview input after transition
Quick play transition: fade
Quick play duration: 500 ms
Performance: Preview skip: 0
Application priority: Normal
Output format: UYVY
Video renderer: VMR9
Enable direct 3D9Ex
Decoders: MPEG 2 video: auto
MPEG audio: auto
x264 video: auto
Direct show filters: Blocked filter list
External output: vMix Video Device (checked)
External recorder (not checked)
Frame rate: NTSC 29.97
Output size: 720 x 480
Device, port, audio device: greyed out
Audio delay: 0
Audio - Master sample rate:48000
Master bit rate: 16 bit PCM
(x)automatically mix audio
(x)show master audio meter in main window
(x)show audio meter next to inputs
(x)fade to black includes audio
Default input audio delay:0
Audio outputs - Master output: default windows playback device
Headphones: default windows playback device
A: none
B: none
Default bus for now inputs: master
Web- (x) enabled
Port: 8088
-STREAMING SETTINGS-
Profile: default
Destination: custom RTMPserver
URL: (correct from ustream)
Stream key: correct from ustream)
Frame rate: 29.97
Quality: H264 480p 950 kbps MP3 96 kbps
Hopefully this is enough information to be helpful in finding a solution (perhaps too much info).
vMix will still lock up without streaming but it takes a little longer.
This is a new computer and setup - issue has been there since the beginning.
I appears just the "camera" (blackmagic) input is the only one with problems. Source video (MP4) with title overlays, etc - no problems.
I cannot stream for more than just a few minutes.
When I said the camera input locks up - in other words, in the output window, it acts like a freeze frame (like it captured one frame of video) and then will not work. Closing vMix at this point send me to the beloved blue screen of death (with the error PFN_LIST_CORRUPT.
Not sure how to reset input prior to shutting down.
I have not monitored CPU cores/memory but will try that next.
Sorry for the lengthy post. I've been a video producer for nearly 30 years but have not worked with streaming video until this project. Nothing like being an old newbie.
Any help is certainly appreciated.
Best, Jeff
#5 Posted : Monday, September 1, 2014 12:52:41 AM(UTC)
Hi Jeff,
Can you try streaming with vMix without the intensity pro plugged in and report if you still have the same issue?
If it runs fine then it is likely the card is faulty or not compatible with that particular system.
anderson
#6 Posted : Monday, September 1, 2014 12:59:54 AM(UTC)
anderson
Thanks Martin for the suggestion. I will give that a try.
Regards, Jeff
anderson
#7 Posted : Monday, September 1, 2014 1:22:51 AM(UTC)
anderson
Well I uninstalled the Blackmagic Intensity Pro card, dropped a few short videos into vMix, streamed it for a few minutes...no issues. So obviously there's an issue with the capture card drivers or perhaps the card itself. Unfortunately I purchased it nearly 2 months ago so likely I won't be able to return it if needed. I'll reinstall the card and see if that works.
Best, Jeff
#8 Posted : Monday, September 1, 2014 3:18:57 AM(UTC)
Maybe not applicable here but check out the cable to the card from the camera too.
Had an issue myself recently to a point I also thought the card was fried or even the camera itself. Turned out to be a cable extention connector.
Guest (5)
