Gigabrain
#1 Posted : Tuesday, April 15, 2025 3:48:26 AM(UTC)
Gigabrain
Hey y'all,
I have recently been having issues with my vMix and computer. My vMix crashed right before a show today. I went into event viewer -> Windows logs -> application logs. I see the application crashing event for vMix.
It reads:
Faulting application name: vMix64.exe, version: 27.0.0.69, time stamp: 0x65cadaa3
Faulting module name: avcodec-58.dll, version: 58.35.100.0, time stamp: 0x6062a71a
Exception code: 0xc0000005
Fault offset: 0x000000000025d949
Faulting process id: 0x0x466C
Faulting application start time: 0x0x1DBAD5575538ED1
Faulting application path: C:\Program Files (x86)\vMix\vMix64.exe
Faulting module path: C:\ProgramData\vMix\vc\x64\avcodec-58.dll
Report Id: ee9983e8-2119-4b5c-8009-d89dc7296a44
Faulting package full name:
Faulting package-relative application ID:
I'm not technically savvy enough and haven't found great resources that point me in the right direction towards the potential problem. Any guidance or assistance is appreciated.
#2 Posted : Tuesday, April 15, 2025 12:07:30 PM(UTC)
Was thanked: 4745 time(s) in 1631 post(s)
Unfortunately in most cases this specific error is due to a fault in some Intel 13th and 14th gen processors.
So my guess is you have a 13xxxk or 14xxxk processor installed?
If so the only fix is to get the CPU replaced under warranty.
Olivier Riou
#3 Posted : Wednesday, April 30, 2025 11:14:09 PM(UTC)
Olivier Riou
Hello, I got the same issue 'till few weeks.
Vmix crash "by itself" every xx minutes even you don't do anything manually.
My system runs -- Intel(R) Core(TM) i7-14700KF 3.40 GHz, If I understand your answer, that kind of cpu should be the problem.
As the sytems ran perfectly 'till november 2024 (24/7) I'm wondering if you think that the CPU issue you mentioned could appears after some monthes so due to lifetime using ?
Here comes the system error (in french)
Nom de l'application défaillante : VMIX64.EXE, version : 28.0.0.41, horodatage : 0x680a57d3
Nom du module défaillant : avcodec-58.dll, version : 58.35.100.0, horodatage : 0x6062a71a
Fault offset: 0x000000000025e658
Identifiant du processus défaillant : 0x10EC
Heure de début de l'application défaillante : 0x1DBB9BD2B7BF7A4
Chemin de l'application défaillante : C:\Program Files (x86)\vMix\VMIX64.EXE
Chemin du module défaillant : C:\ProgramData\vMix\vc\x64\avcodec-58.dll
ID du rapport : b8a4c2cd-9c4e-44b9-87d3-681720883958
Nom complet du package défaillant :
Package défaillant – ID d'application relatif :
Regards
Olivier
#4 Posted : Thursday, May 1, 2025 1:07:17 AM(UTC)
Yes, this specific Intel CPU fault starts to appear slowly over time, so we have seen many start to fail after many months of usage.
nikosman88
#5 Posted : Thursday, May 1, 2025 3:56:29 AM(UTC)
nikosman88
Greece
Hi. With all respect if this happens,the reference system "topaz" should not be any more as reference if there is any chance after some months the 13900kf cpu die and hang the users.
#6 Posted : Thursday, May 1, 2025 11:42:21 AM(UTC)
Intel's guidance is if you buy one of these CPUs today, and have the latest motherboard bios updates, they will not degrade over time.
Additionally, Intel will replace any already degraded CPU under warranty.
https://community.intel....-Root-Cause/post/1633239
That said, we are working on new reference systems as the CPUs are starting to become out of date anyway.
sinc747 on 5/9/2025(UTC)
Olivier Riou
#7 Posted : Saturday, May 3, 2025 7:50:45 PM(UTC)
Olivier Riou
Hello, thanks a lot for your answers to that topic.
I want to share what I did after reading your answers.
1 - I installed "Process Lasso" to be sure vMix would no longer use CPU IDs from 0 to 7 (which are likely the most used cores and therefore should be the most degraded)
==> vMix ran for 24 hours and finally crashed because of "nvcuvid.dll", so it was a NVIDIA issue.
2 - I updated the NVIDIA driver
3 - According to the Intel link you mentioned, I updated the motherboard firmware (I found one that addressed the default)
Then I tried working extensively with vMix, opening/closing presets, adding/removing inputs, etc.
For the moment, there have been no other crashes at all.
I hope this information could help someone else.
Olivier
