Bonete2
#1 Posted : Friday, February 21, 2025 5:13:09 PM(UTC)
Bonete2
"It is not possible to add inputs greater than 300 to shortcuts or triggers because they do not appear in the dropdown menu."
#2 Posted : Friday, February 21, 2025 6:18:47 PM(UTC)
(Shortcut) Have you tried using the function within a script ?
#3 Posted : Friday, February 21, 2025 7:27:19 PM(UTC)
Was thanked: 4759 time(s) in 1633 post(s)
This is not a bug as it is by design.
If you need to assign shortcuts to over 300 inputs then you will likely run into severe performance issues, and should rethink the entire setup anyway.
If you only need to assign shortcuts to a number under that, than simply sort the inputs you need in the first 300.
Or, as mentioned there are many other ways to do things such as with scripting.
