the list shorcuts dont work after input 300
"It is not possible to add inputs greater than 300 to shortcuts or triggers because they do not appear in the dropdown menu."
Originally Posted by: Bonete2  "It is not possible to add inputs greater than 300 to shortcuts or triggers because they do not appear in the dropdown menu." (Shortcut) Have you tried using the function within a script ?
Joined: 1/13/2010(UTC) Posts: 5,371  Location: Gold Coast, Australia Was thanked: 4796 time(s) in 1647 post(s)
This is not a bug as it is by design. If you need to assign shortcuts to over 300 inputs then you will likely run into severe performance issues, and should rethink the entire setup anyway.
If you only need to assign shortcuts to a number under that, than simply sort the inputs you need in the first 300.
Or, as mentioned there are many other ways to do things such as with scripting.
