Bic Hauser
#1 Posted : Friday, December 13, 2024 3:58:57 AM(UTC)
Bic Hauser
I can set keyboard shortcuts to SetOutputs 2, 3 and 4 to different inputs.
How do I set a keyboard shortcut to SetOutput1 to another input?
I can change it manually of course... Does SetOutput1 go by another name?
nikosman88
#2 Posted : Friday, December 13, 2024 4:24:27 AM(UTC)
nikosman88
Greece
Hello. There is no shortcut for output 1. This has been discussed over years and asked for feature request but still is not implemented
https://forums.vmix.com/...rtcut-to-change-Output-1
https://forums.vmix.com/...03-Shortcut-for-Output-1
some threads about this and to take ideas for workaround until this shortcut appear in a vmix future version
vmixgreg
#3 Posted : Friday, December 13, 2024 4:35:22 AM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Was thanked: 22 time(s) in 21 post(s)
Essentially, since the External Output [1] is directly linked to the Record/Stream/External Output and the vMix main Program Output has to go to either the Fullscreen [1] Output and/or the External [1] Output, it is deemed that it should never be required to change that via a Shortcut or the API and should only be done manually if and when required in order to avoid confusion and/or prevent mistakes.
vMix Greg
spinfold
#4 Posted : Friday, December 13, 2024 5:30:51 AM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
You just change what is in Programme.
That is Output 1.
