SetOutput1 to another input by Shortcut
I can set keyboard shortcuts to SetOutputs 2, 3 and 4 to different inputs. How do I set a keyboard shortcut to SetOutput1 to another input? I can change it manually of course... Does SetOutput1 go by another name?
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 65 Location: Canada
Thanks: 1 times Was thanked: 20 time(s) in 19 post(s)
Essentially, since the External Output [1] is directly linked to the Record/Stream/External Output and the vMix main Program Output has to go to either the Fullscreen [1] Output and/or the External [1] Output, it is deemed that it should never be required to change that via a Shortcut or the API and should only be done manually if and when required in order to avoid confusion and/or prevent mistakes.
vMix Greg
Joined: 1/23/2022(UTC) Posts: 131  Location: Milton Keynes Thanks: 14 times Was thanked: 14 time(s) in 14 post(s)
You just change what is in Programme.
That is Output 1.
