I re-installed my vMix on my new laptop. Every mp4 video I try to import are showing dark. Sound is working but can't seem to get any images. If I check the input setting under General, the resolution is showing 0x0.
How do I fix that and show my video. I can't use vMix like that. I've downloaded new video just in case my old imported video were the issue to no avail. They are still showing dark.
I had these settings correct but this time I changed also changed the 'Desktop' setting to allow 'Video Editing'. Restarted my laptop and it worked. The image came back. Thanks for your prompt reply.
