julien
#1 Posted : Wednesday, November 27, 2024 12:14:34 AM(UTC)
julien
I encountered a compatibility problem with the new update of the desktop video 14.3 by putting the card with this version.
Impossible to find the inputs in VMIX, only available in legacy WDM and no image. I had to downgrade to the old version 12.7.1 from 17 october 2023 (I do not know from which version this problem appears), I find again my 4 decklink inputs.
I am under windows 11 pro, with an rtx 4060 card, an intel I7 14700 and chipset asus Z790.
If it can help some people.
julien.
Slaver
#2 Posted : Wednesday, November 27, 2024 10:45:24 PM(UTC)
Slaver
Was thanked: 8 time(s) in 8 post(s)
Got the same Problem with DeckLink Quad 2 and blackmagic 14.3
I installed the 14.2 to get them back.
Crazy.
#3 Posted : Friday, November 29, 2024 3:09:54 AM(UTC)
Was thanked: 4729 time(s) in 1621 post(s)
We have confirmed there is a compatibility issue with the Decklink 14.3 drivers and vMix.
The solution for now is to rollback and install Decklink 14.2 or earlier.
This is due to Blackmagic removing support for some SDK versions in the latest driver.
We will release a fix soon for vMix 27 and 28 to support 14.3 as well.
TemporalKinetics
#4 Posted : Wednesday, December 11, 2024 1:03:06 PM(UTC)
TemporalKinetics
I was having a similar issue and got inputs to work with 14.2.1 and vMix 25, but was having trouble with getting an Output to work. I tried a variety of versions of the Blackmagic software and finally got (I believe it was 14.1) to work, but after I updated to vMix 27, it would no longer work. Tried 14.3 (thinking that was fixed in 27.0.89, but no avail. Then I downgraded to 14.1. Nothing. Then I created a NEW vMix profile and it worked.
Is it possible something is stuck in the old profile to prohibit it? I made sure port 4 was not set as an Input (though it was before). I'm rebuilding the profile and will see where it goes, but thought this info might be helpful to someone.
shaiz
#5 Posted : Wednesday, March 12, 2025 7:08:20 PM(UTC)
shaiz
i had the same problem. fixed with the 14.5 version
2 Stream
#6 Posted : Tuesday, April 29, 2025 12:44:53 AM(UTC)
2 Stream
We have the same issue. Tested with 14.5 and no luck. Downgraded to 14.2 and it works.
Working on the latest VMIX.
anilshivamber
#7 Posted : Friday, February 27, 2026 9:10:50 PM(UTC)
anilshivamber
i am using vmix trail and i install the DeckLink Quad HDMI Recorder HDMI the device manager it install but does not show up in vmix
and advice
thank you
jet
#8 Posted : Saturday, February 28, 2026 5:37:16 PM(UTC)
jet
Was thanked: 26 time(s) in 24 post(s)
Originally Posted by: TemporalKinetics Go to Quoted Post
I was having a similar issue and got inputs to work with 14.2.1 and vMix 25, but was having trouble with getting an Output to work... ... Then I created a NEW vMix profile and it worked.
Recently had the same issue: vMix (29.0.0.44) did not allow output to "Deck Link Duo" -card. To me it seems that the settings file of vMix gets some times corrupted. Reset to Defaults in vMix Settings did the trick, but then I had to re-configure ALL the other stuff also...
I would recommend everyone to install "BMD Desktop Video" V 15.3.1 hence it updates the internal firmware of "Deck Link Duo 2" and it should fix some of the issues people are having with it.
Guest (4)
