Hardware Compatibility
Issue Decklink Duo 2 and desktop video 14.3 (only legacy wdm input vmix)
Hi, I encountered a compatibility problem with the new update of the desktop video 14.3 by putting the card with this version. Impossible to find the inputs in VMIX, only available in legacy WDM and no image. I had to downgrade to the old version 12.7.1 from 17 october 2023 (I do not know from which version this problem appears), I find again my 4 decklink inputs. I am under windows 11 pro, with an rtx 4060 card, an intel I7 14700 and chipset asus Z790. If it can help some people.
julien.
Thanks: 27 times Was thanked: 8 time(s) in 8 post(s)
Got the same Problem with DeckLink Quad 2 and blackmagic 14.3
I installed the 14.2 to get them back.
Crazy.
Joined: 1/13/2010(UTC) Posts: 5,337  Location: Gold Coast, Australia Was thanked: 4739 time(s) in 1626 post(s)
We have confirmed there is a compatibility issue with the Decklink 14.3 drivers and vMix. The solution for now is to rollback and install Decklink 14.2 or earlier.
This is due to Blackmagic removing support for some SDK versions in the latest driver. We will release a fix soon for vMix 27 and 28 to support 14.3 as well.
I was having a similar issue and got inputs to work with 14.2.1 and vMix 25, but was having trouble with getting an Output to work. I tried a variety of versions of the Blackmagic software and finally got (I believe it was 14.1) to work, but after I updated to vMix 27, it would no longer work. Tried 14.3 (thinking that was fixed in 27.0.89, but no avail. Then I downgraded to 14.1. Nothing. Then I created a NEW vMix profile and it worked.
Is it possible something is stuck in the old profile to prohibit it? I made sure port 4 was not set as an Input (though it was before). I'm rebuilding the profile and will see where it goes, but thought this info might be helpful to someone.
i had the same problem. fixed with the 14.5 version
We have the same issue. Tested with 14.5 and no luck. Downgraded to 14.2 and it works. Working on the latest VMIX.
i am using vmix trail and i install the DeckLink Quad HDMI Recorder HDMI the device manager it install but does not show up in vmix
and advice
thank you
Joined: 11/14/2012(UTC) Posts: 388  Location: Finland Thanks: 247 times Was thanked: 33 time(s) in 31 post(s)
Originally Posted by: TemporalKinetics  I was having a similar issue and got inputs to work with 14.2.1 and vMix 25, but was having trouble with getting an Output to work... ... Then I created a NEW vMix profile and it worked.
Is it possible something is stuck in the old profile to prohibit it? I made sure port 4 was not set as an Input (though it was before). I'm rebuilding the profile and will see where it goes, but thought this info might be helpful to someone. Recently had the same issue: vMix (29.0.0.44) did not allow output to "Deck Link Duo" -card. To me it seems that the settings file of vMix gets some times corrupted. Reset to Defaults in vMix Settings did the trick, but then I had to re-configure ALL the other stuff also... I would recommend everyone to install "BMD Desktop Video" V 15.3.1 hence it updates the internal firmware of "Deck Link Duo 2" and it should fix some of the issues people are having with it.
