Cryptic662
#1 Posted : Monday, November 18, 2024 1:47:14 AM(UTC)
Cryptic662
I am considering upgrading my production PC to the 9800x3d. I was wondering if anyone has any data on how well vmix works on those CPUs before I jump from intel.
nikosman88
#2 Posted : Tuesday, November 19, 2024 8:08:19 AM(UTC)
nikosman88
Greece
Hi. I made a search and dont find people to use for vmix the x3d cpu either 5700/5800 or am5 7800 as 9800 is new for now.
My personal opinion is that for vmix cpu cores matter so even the x3d has the cache,it still is 8/16 cpu. When the 9950x is 16/32. So my personal choice for productivity would be the 9950x.
Except this see also this https://www.vmix.com/kno.../amd-cpu-support-in-vmix
If you need a really high end pc the amd way is threadripper and intel way x299 cpu/socket. Cause even the higher 9000x series of amd and also in the intel world the new ultra 9 still use dual memory channel,when vmix faq says that for 4k or many hd channels we need 4 channels memory
Also you can ask vmix support sales department for better advice https://www.vmix.com/contact-us.aspx
Cryptic662
#3 Posted : Tuesday, November 19, 2024 8:36:26 AM(UTC)
Cryptic662
Hey. Thanks for the reply!
kross
#4 Posted : Tuesday, November 26, 2024 2:30:04 PM(UTC)
kross
Was thanked: 44 time(s) in 43 post(s)
I'm not using that exact CPU, but I am using an AMD 7900X3D, and have been very happy with the performance. Usually 4 or 5 HDMI cameras (1080p60) with replay. Remote callers with vmix call. No issues. Very pleased.
Cryptic662
#5 Posted : Monday, December 9, 2024 6:08:17 AM(UTC)
Cryptic662
Thanks for the reply. I went with the 7950x3d and i have been really happy with it so far. I had a slight issue with frame drops until i enabled gsync. I use a 4 monitor setup on 1 pc and vmix never really seems to like having multiple monitors, but enabling gsync worked like a charm
kross
#6 Posted : Monday, December 9, 2024 6:24:03 AM(UTC)
kross
I'm glad you're having success. I have 3 monitors on my setup. I never did anything special with gsync or anything like that, and haven't had any issues. But congrats on the upgrade! :)
