I am considering upgrading my production PC to the 9800x3d. I was wondering if anyone has any data on how well vmix works on those CPUs before I jump from intel.
Hi. I made a search and dont find people to use for vmix the x3d cpu either 5700/5800 or am5 7800 as 9800 is new for now. My personal opinion is that for vmix cpu cores matter so even the x3d has the cache,it still is 8/16 cpu. When the 9950x is 16/32. So my personal choice for productivity would be the 9950x. Except this see also this https://www.vmix.com/kno.../amd-cpu-support-in-vmixIf you need a really high end pc the amd way is threadripper and intel way x299 cpu/socket. Cause even the higher 9000x series of amd and also in the intel world the new ultra 9 still use dual memory channel,when vmix faq says that for 4k or many hd channels we need 4 channels memory Also you can ask vmix support sales department for better advice https://www.vmix.com/contact-us.aspx
Hey. Thanks for the reply!
Joined: 10/31/2020(UTC) Posts: 197  Thanks: 6 times Was thanked: 44 time(s) in 43 post(s)
I'm not using that exact CPU, but I am using an AMD 7900X3D, and have been very happy with the performance. Usually 4 or 5 HDMI cameras (1080p60) with replay. Remote callers with vmix call. No issues. Very pleased.
Thanks for the reply. I went with the 7950x3d and i have been really happy with it so far. I had a slight issue with frame drops until i enabled gsync. I use a 4 monitor setup on 1 pc and vmix never really seems to like having multiple monitors, but enabling gsync worked like a charm
I'm glad you're having success. I have 3 monitors on my setup. I never did anything special with gsync or anything like that, and haven't had any issues. But congrats on the upgrade! :)
