Attempted to read or write protected memory error on start up
Joined: 1/21/2021(UTC) Posts: 8  Location: Whitley Bay Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
All my vmix presets are suddenly crashing on start up with this message 'Attempted to read or write protected memory. This is often an indication that other memory is corrupt'
I have checked on this forum and in the past several people experienced it and the solution was to update nvidia and intel drivers
I have done this to no avail and am now performing a memory test on my system.
Z370-F Motherboard I9 9900K RTX2080TI 32MB Ram Nvidia Drivers up to date 528.49
I had recently updated a Waves plugin (Clarity v14.0) but still have the issue after uninstalling it
Interesting when I open a brand new vmix instance it is fine, it is just the pre-made presets that are crashing
** UPDATE ** It seems the upgrade to Clarity V14 is the issue here as it has also happened to my colleague who upgraded at the same time. We have found a workaround but it is a bit long winded. If you have the same problem let me know if you have got around it or I can share my solution
Joined: 5/5/2020(UTC) Posts: 7  Location: Florida Thanks: 3 times
Hi, it appears I'm having the same issue but only with a certain preset. I also just updated the Clarity v14.0. Any help with the workaround for this would be much appreciated. Thank you!
Hi, I tried a few things but the thing that did the trick for me was removing the file 'WaveShell1-VST3 13.5_x64.vst3' from C:\Program Files\Common Files\VST3. I think this stops vmix trying to access the old version of Clarity from the plugins folder. If that doesn't work, try uninstalling Waves Central and then re-installing. If they don't work, try removing any reference to the Waves 13.5 plugin from any audio input you have it on and re-saving the preset without.
 1 user thanked byevad for this useful post.
I am having the same issues. Help
Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 99 time(s) in 95 post(s)
Originally Posted by: Priceal  I am having the same issues. Help Hi. Vmix version? Windows version? Any vst3 plugins?
