byevad
#1 Posted : Saturday, February 18, 2023 3:04:54 AM(UTC)
byevad
All my vmix presets are suddenly crashing on start up with this message 'Attempted to read or write protected memory. This is often an indication that other memory is corrupt'
I have checked on this forum and in the past several people experienced it and the solution was to update nvidia and intel drivers
I have done this to no avail and am now performing a memory test on my system.
Z370-F Motherboard
I9 9900K
RTX2080TI
32MB Ram
Nvidia Drivers up to date 528.49
I had recently updated a Waves plugin (Clarity v14.0) but still have the issue after uninstalling it
Interesting when I open a brand new vmix instance it is fine, it is just the pre-made presets that are crashing
** UPDATE ** It seems the upgrade to Clarity V14 is the issue here as it has also happened to my colleague who upgraded at the same time. We have found a workaround but it is a bit long winded. If you have the same problem let me know if you have got around it or I can share my solution
Cupofjoe959
#2 Posted : Thursday, March 9, 2023 7:46:25 AM(UTC)
Cupofjoe959
Hi, it appears I'm having the same issue but only with a certain preset. I also just updated the Clarity v14.0. Any help with the workaround for this would be much appreciated. Thank you!
byevad
#3 Posted : Thursday, March 9, 2023 11:44:26 PM(UTC)
byevad
Hi, I tried a few things but the thing that did the trick for me was removing the file 'WaveShell1-VST3 13.5_x64.vst3' from C:\Program Files\Common Files\VST3. I think this stops vmix trying to access the old version of Clarity from the plugins folder. If that doesn't work, try uninstalling Waves Central and then re-installing. If they don't work, try removing any reference to the Waves 13.5 plugin from any audio input you have it on and re-saving the preset without.
thanks 1 user thanked byevad for this useful post.
dasmedienatelier on 12/10/2025(UTC)
Priceal
#4 Posted : Monday, November 25, 2024 11:28:17 PM(UTC)
Priceal
I am having the same issues.
Help
nikosman88
#5 Posted : Monday, November 25, 2024 11:55:59 PM(UTC)
nikosman88
Greece
Help
Hi. Vmix version? Windows version? Any vst3 plugins?
