NDI
Help Need! SOS - NDI one desktop can not see the other
Joined: 2/4/2021(UTC) Posts: 23   Location: Porter Ranch
I keep running this same issue and need help again. Please advise.
I have two desktops on the same Wifi LAN. A PC and a MAC.
iMAC PC PC can see iMac on NDI But iMac can not see PC on the NDI. iMac can only see itself In such a case, what should I do differently?
I was able to see the PC on iMac just this morning.
Thanks a lot.
Jing
Joined: 4/23/2017(UTC) Posts: 1,481  Location: Germany Thanks: 3 times Was thanked: 196 time(s) in 176 post(s)
Use a wired connection and you will be able to receive it.
Mavik,
I did. And I tried again. It does not help.
My Mac and PC are both on the same wired network already.
And previously, as long both are in the same WIFI network, they see each other.
Even now, PC can see the Mac without any problem.
Jing
If computers have multiple NICs the metric decides which NIC gets prioritized. Either you configure the metric that the appropriate NIC is used or you simply disable wifi. This way you ensure that the traffic is really flowing over the wire and not the air.
Mavic, how to prioritize NIC?
Do you have a step by step?
And Mavic, I disabled the Wifi on both machines.
I see no difference. There is still no display of the PC on the virtual input of the NDI virtual input display on the Mac. At the same time, regardless if I disable the wifi or not, my PC can always see my mac on NDI. It just does not flow the other way around.
Jing
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Just as a reminder, it is always a good idea to post your solution, a) as a reference for people who have the same problem, and b) out of politeness to the people that have taken the time to help you.
 1 user thanked dmwkr for this useful post.
NDI
