gujingc
#1 Posted : Wednesday, November 13, 2024 7:23:40 PM(UTC)
gujingc
I keep running this same issue and need help again. Please advise.
I have two desktops on the same Wifi LAN. A PC and a MAC.
iMAC
Imac logged into the Wifi Network
PC
PC logged into the Wifi network
PC can see iMac on NDI
PC can see iMac through NDI
But iMac can not see PC on the NDI. iMac can only see itself
iMac can not see PC.
In such a case, what should I do differently?
I was able to see the PC on iMac just this morning.
Thanks a lot.
Jing
mavik
#2 Posted : Wednesday, November 13, 2024 11:09:03 PM(UTC)
mavik
Use a wired connection and you will be able to receive it.
gujingc
#3 Posted : Thursday, November 14, 2024 3:34:14 AM(UTC)
gujingc
Mavik,
I did. And I tried again. It does not help.
My Mac and PC are both on the same wired network already.
And previously, as long both are in the same WIFI network, they see each other.
Even now, PC can see the Mac without any problem.
Jing
mavik
#4 Posted : Thursday, November 14, 2024 5:38:54 AM(UTC)
mavik
If computers have multiple NICs the metric decides which NIC gets prioritized. Either you configure the metric that the appropriate NIC is used or you simply disable wifi. This way you ensure that the traffic is really flowing over the wire and not the air.
gujingc
#5 Posted : Thursday, November 14, 2024 9:48:06 AM(UTC)
gujingc
Mavic, how to prioritize NIC?
Do you have a step by step?
gujingc
#6 Posted : Thursday, November 14, 2024 9:50:32 AM(UTC)
gujingc
And Mavic, I disabled the Wifi on both machines.
I see no difference. There is still no display of the PC on the virtual input of the NDI virtual input display on the Mac.
PC not showing up on the mac virtual input
At the same time, regardless if I disable the wifi or not, my PC can always see my mac on NDI.
Mac at the same time is showing as NDI input on PC.
It just does not flow the other way around.
Jing
gujingc
#7 Posted : Thursday, November 14, 2024 12:20:47 PM(UTC)
gujingc
I solved it. Yay!
dmwkr
#8 Posted : Friday, November 15, 2024 1:14:00 AM(UTC)
dmwkr
Was thanked: 160 time(s) in 144 post(s)
Just as a reminder, it is always a good idea to post your solution, a) as a reference for people who have the same problem, and b) out of politeness to the people that have taken the time to help you.
thanks 1 user thanked dmwkr for this useful post.
eduardocfs on 11/18/2024(UTC)
