knbPixels
#1 Posted : Friday, October 11, 2024 2:50:09 AM(UTC)
knbPixels
Wanted to see if anyone else is experiencing thing, and if it's just how the software works, or if there's a problem. When I have an input that is used on a layer of another input, and I crop the original input, that cropping isn't reflected on the other inputs where it's used as a layer. Zoom, rotate, and pan are all reflected on the other uses of that input, so why not crop?
WaltG12
#2 Posted : Friday, October 11, 2024 4:06:06 AM(UTC)
WaltG12
Did you check the box for cropping?
Because I only see the behavior you described when the box is ticked to allow for a custom crop.
thanks 1 user thanked WaltG12 for this useful post.
knbPixels on 10/11/2024(UTC)
knbPixels
#3 Posted : Friday, October 11, 2024 4:29:33 AM(UTC)
knbPixels
Yep, that did it, thanks!!
sinc747
#4 Posted : Friday, October 11, 2024 6:18:46 AM(UTC)
sinc747
A work around for this is to the take the input you want to crop and add it to a Mix Input as the Output. Then use the Mix Input in place of the original input in the layer.
Clear as mud, right?
- Tom
Guest (4)
