Cropping an input that's used as a layer
Joined: 2/7/2024(UTC) Posts: 194  Thanks: 13 times Was thanked: 7 time(s) in 6 post(s)
Wanted to see if anyone else is experiencing thing, and if it's just how the software works, or if there's a problem. When I have an input that is used on a layer of another input, and I crop the original input, that cropping isn't reflected on the other inputs where it's used as a layer. Zoom, rotate, and pan are all reflected on the other uses of that input, so why not crop?
Joined: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Did you check the box for cropping?
Because I only see the behavior you described when the box is ticked to allow for a custom crop.
 1 user thanked WaltG12 for this useful post.
Originally Posted by: WaltG12  Did you check the box for cropping?
Because I only see the behavior you described when the box is ticked to allow for a custom crop. Yep, that did it, thanks!!
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 204 time(s) in 170 post(s)
A work around for this is to the take the input you want to crop and add it to a Mix Input as the Output. Then use the Mix Input in place of the original input in the layer.
Clear as mud, right?
- Tom
