ask
#1 Posted : Friday, March 28, 2014 11:24:52 PM(UTC)
ask
Hi Martin,
No big issue but the installer will not replace vMixVideo.ax when I do an in-place upgrade. I choose ignore and the install proceeds. vMix seems to function normally afterwards. Any ideas?
Andrew
#2 Posted : Saturday, March 29, 2014 1:16:12 AM(UTC)
Hi Andrew,
It is important that vMix Video be updated during installation to make sure it is the latest version.
The error usually means something like skype is running in the background with a connection to the file.
ask
#3 Posted : Saturday, March 29, 2014 8:36:47 AM(UTC)
ask
Thanks..please get some sleep! Man can't live off brown carbonated beverages alone!!! LOL
ask
#4 Posted : Tuesday, July 1, 2014 6:31:21 AM(UTC)
ask
Finally tracked down the program. It seems that both Skpye and Avermedia RECentral are the culprits. Interestingly I could quit Sskpye and that released the file but RECentral was not operating but still had a connection. So the workaround was to rename the .ax file, then run the new install.
clibil
#5 Posted : Tuesday, April 9, 2024 10:56:34 PM(UTC)
clibil
Just to say that the problem with Skype needing to be shut down is still occurring today with v.27
Shut down Skype - problem solved!
Lastmarine
#6 Posted : Tuesday, September 3, 2024 7:21:19 PM(UTC)
Lastmarine
I've been experiencing this issue with the previous two installs 0.80 and 0.83 and I do not have Skype running or even installed on one of my computers. Any idea what could be causing it? I guess I could try and remove the file manually then run the install.
thanks 1 user thanked Lastmarine for this useful post.
Chircanu on 9/3/2024(UTC)
mavik
#7 Posted : Monday, October 7, 2024 6:58:18 PM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
The same happened to me today with V27.85. Could it be some O365 stuff like Teams having a handle on it.
stevethornley
#8 Posted : Monday, February 24, 2025 7:15:57 PM(UTC)
stevethornley
Just to add to this for future users.
Had exactly the same issue but were not running Skype or any AverMedia products. Found the issue to be the 'new' version of Outlook. Removed this and installation worked fine although did download and install a 'fresh' version rather than do through the very old v24 we were using prior to an unplanned Win11 24H2 upgrade.
All seems to be OK now.
Roy Sinclair
#9 Posted : Thursday, February 27, 2025 8:50:01 AM(UTC)
Roy Sinclair
Was thanked: 31 time(s) in 27 post(s)
Best solution is to just boot to the Safe Mode version of windows and then install. That way all the other programs that MIGHT be using the A/V subsystems in Windows won't get started.
Of course by figuring out what IS using that you can also find background nonsense that probably SHOULDN'T be running.
