52 Pages«<4849505152>
raugert
#981 Posted : Wednesday, June 19, 2024 8:13:24 AM(UTC)
raugert
Canada
Simply create 2 buttons to scroll through the presets in the title.. One button for "Next" and another for "Previous"
Then, to change a preset in a title you would use the command "NextTitlePreset" or PreviousTitlePreset" . If you are using a DataSource then you would use the "DataSourceNextRow" or the "DataSourcePreviousRow" commands.
barryondeck
#982 Posted : Friday, June 21, 2024 12:08:44 AM(UTC)
barryondeck
Got it. Yeah, I knew that method from reading about it, but I was wondering if I could change it dynamically on the fly live during my stream.
Sounds like I can't. No worries. Thanks for the reply.
Luis70
#983 Posted : Monday, September 2, 2024 11:52:02 PM(UTC)
Luis70
Grenada
Thanks Given:
Anything new to look out for anytime soon?....haven't seen any updates lately
raugert
#984 Posted : Saturday, September 7, 2024 3:50:46 AM(UTC)
raugert
Canada
Sorry, I've been busy with renovations this summer. Not much time for coding. Hopefully get back to it soon...
cheers,
Richard
thanks 1 user thanked raugert for this useful post.
Luis70 on 9/7/2024(UTC)
Luis70
#985 Posted : Saturday, September 7, 2024 12:57:46 PM(UTC)
Luis70
Grenada
Thanks Given:
ok, hope to see some new features soon....especially with the audio sliders.....just make them plain, no background, the way you first had the "T-Bar" ... let me decide what type of scale or background I want
Chumbaz
#986 Posted : Wednesday, September 18, 2024 8:51:08 PM(UTC)
Chumbaz
Italy
I can't find a solution in managing tally status
If i create a button, and I assign to it an AUDIO device, the tally "light" works fine, no problem
But if I create a script, and i turn on/off the same AUDIO device with the script, of course the "light" can't be engaged
Is there a way to "connect" the "tally light" status without connecting the button directly to a device?
OR
Is there a way to connect the button to a device AND to launch a script?
OR
any turnaround to manage the button colo/content inside a script (even better)?
Thank you very much
Luis70
#987 Posted : Wednesday, September 18, 2024 11:39:33 PM(UTC)
Luis70
Grenada
Thanks Given:
I have the same issue, but in some cases, I ran triggers, and got some results....maybe you should try triggers until a way is discovered ... there is a way, but I can not get it to work on my end
Chumbaz
#988 Posted : Wednesday, September 18, 2024 11:50:55 PM(UTC)
Chumbaz
Italy
i will start to take a look...
but it is not a real solution in my opinion
but thank you of course
Luis70
#989 Posted : Thursday, September 19, 2024 12:45:37 AM(UTC)
Luis70
Grenada
Thanks Given:
Function=SetColor&Input=Test color box.gtzip&Value=#FF0000&SelectedName=Rectangle1.Fill.Color
Function=(Here you will add whatever functions you have)
Function=SetColor&Input=Test color box.gtzip&Value=#00FF00&SelectedName=Rectangle1.Fill.Color
Think I had to create a colour box in GT Titler to get it to work ... I think I see why it did not work for me.....when I get a chance, I will do some tests (#00FF00&SelectedName=Rectangle1.Fill.Color)...I think that should be Rectangle2.fill.color, as there will be 2 colours for your tally....tell if it worked for you
Chumbaz
#990 Posted : Thursday, September 19, 2024 12:49:37 AM(UTC)
Chumbaz
Italy
with this approach youll change the color of a rectangle in a TITLE
NOT in the PANEL
which actually is what i am looking for
but, of course, thank you
Luis70
#991 Posted : Thursday, September 19, 2024 2:12:09 AM(UTC)
Luis70
Grenada
Thanks Given:
Let me know if, or how it worked....
WaltG12
#992 Posted : Thursday, September 19, 2024 3:20:06 AM(UTC)
WaltG12
If you're open to switching to your browser, the Web Controller has a title editor.
If you're using the same title input, which it sounds like you are, you can even add a favorite icon to your iPad's home screen to take you directly to the editor for that title.
Luis70
#993 Posted : Tuesday, September 24, 2024 7:04:19 AM(UTC)
Luis70
Grenada
Thanks Given:
Then your first line in your Script should be :
Function=SetColor&Input=ColorPlaceholder.gtzip&Value=#FF0000&SelectedName=Color1.Fill.Color (this will change the button to Red when the script starts)
The last line in your Script would be :
Function=SetColor&Input=ColorPlaceholder.gtzip&Value=#00FF00&SelectedName=Color1.Fill.Color (this will change the button to Green when the script ends)
You can change the hex values if you want different colors...
This is the instructions I received, but I could not get it to work correctly
Luis70
#994 Posted : Friday, December 20, 2024 10:42:14 AM(UTC)
Luis70
Grenada
Thanks Given:
hey,...any updates yet?
raugert
#995 Posted : Saturday, December 21, 2024 1:53:51 AM(UTC)
raugert
Canada
Sorry Luis ... nothing yet. Hopefully in the new year.
mairginter@hotmail.com
#996 Posted : Thursday, January 30, 2025 5:27:04 PM(UTC)
Italy
Hello @roguert, first of all I would like to thank you for the vmix panel builder.
I think it's just great tool and I can't understand why Vmix doesn't come with something like this already. I can't imagine doing complex and flexible events without it.
I was pleased to see today that some new shortcuts (e.g. overlays in mix2+) already work out of the box with vmix 28.
Since you might now be thinking of making some adjustments for vmix 28, I wanted to give you a few suggestions for improvements. Perhaps one or two of them will be of interest to you and not too difficult to implement.
1) Copying buttons from a second open instance of the Panel Builder.
I know you can attach entire pages, but I host different events with different requirements that are constantly changing, so it would be very practical and efficient if you could open another template in a second instance and then simply copy and paste individual buttons.
2) Test whether inputs in buttons are available via the API + highlighting of errors
In complex environments, when taking over functions from other templates or when cleaning up Vmix presets, it often happens that the input of a button no longer matches. A function to check and highlight the missing links would save a lot of time and sources of error.
3) A “nice to have” would also be a drop-down list for the companion buttons. First you select the page and then a list of all possible buttons appears.
4) A small problem that I keep running into is that the Panel Builder window does not open visibly. I help myself by dragging the window onto the screen using the Windows snap function. I could imagine that it is because I use different sized touchscreens on my laptop. In the studio 24“ touch and 48” main and on the road 13“ touch and 27” main.
5) Tally for active title - “SelectTitlePreset”. I think you once mentioned that the API doesn't provide this information. Is that still the case?
One question: Am I allowed to advertise the PanelBuilder in Companion circles? I think that it would often be a flexible option for pure Companion users as well.
Thanks again for all your hard work.
raugert
#997 Posted : Saturday, February 1, 2025 12:57:41 PM(UTC)
raugert
Canada
@ mairginter
Thanks for your feedback. I'll look into your suggestions..
Feel free to promote the Panel Builder on the Companion forum if you like. I also use it to simultaneously control ATEM switchers through BitFocus and vMix directly.
cheers,
Richard
LazLong on 2/6/2025(UTC)
Grom
#998 Posted : Wednesday, February 12, 2025 7:17:44 PM(UTC)
Grom
Poland
How do I launch an application on a MacBook? I downloaded it and tried to run it, but it says it's not possible. Thank you.
dmwkr
#999 Posted : Wednesday, February 12, 2025 7:34:09 PM(UTC)
dmwkr
Installation guide can be found in the user guide:
http://cli.re/vmix-panel-builder-user-guide
If it is not working you would need to post at least your Mac OS version.
Luis70
#1000 Posted : Thursday, February 13, 2025 2:38:05 AM(UTC)
Luis70
Grenada
Thanks Given:
The link not working, it does not launch at all
Guest (8)
