Joined: 1/18/2023(UTC) Posts: 2  Location: Guyancourt
Hi Members,
I am currently using an 'AJA Io X3' in my Vmix setup. It allows me to capture 4 video streams from cameras via the Thunderbolt port on my laptop, using SDI. I would like to know if it's possible to use, in addition to my 'AJA Io X3', an 'AJA U-TAP SDI' to add an extra camera through a USB 3 port on my laptop ?
Thanks a lot.
TV78
Joined: 5/19/2021(UTC) Posts: 17  Was thanked: 1 time(s) in 1 post(s)
There’s no reason why that wouldn’t work. Although if you need more channels you may have been better off getting a decklink quad 2 and putting it in a thunderbolt 3 enclosure.
Joined: 10/20/2023(UTC) Posts: 153  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
As said before, there is no reason why it wouldn't work.
In your place, I would add a thunderbolt daisy chain device to the aja
a 2nd aja Io3 or an ultrastudio recorder 3g for example
Thanks: 12 times Was thanked: 1 time(s) in 1 post(s)
Hi!
Can you tell me such a tool?
Thanks!
no tool thunderbolt devices sometimes have 2 thunderbolt ports. This allows you to daisy chain the devices. example :  Element-Dock_Daisy-Chain_P1080528_Edited_December-28-2020_1500px.jpg (154kb) downloaded 5 time(s).in the case of our friend TV78, an aja io3 + a bmd ultrastudio recorder 3g to have its 5 inputs as long as you do not exceed the maximum flow rate that the PC's thunderbolt port can support  AcasisThunderbolt3QuadHDMIChannelVideoCaptureCard_4K60_TP4HD-3.jpg (103kb) downloaded 5 time(s).
