TV78
#1 Posted : Thursday, March 7, 2024 1:58:58 AM(UTC)
TV78
Hi Members,
I am currently using an 'AJA Io X3' in my Vmix setup. It allows me to capture 4 video streams from cameras via the Thunderbolt port on my laptop, using SDI. I would like to know if it's possible to use, in addition to my 'AJA Io X3', an 'AJA U-TAP SDI' to add an extra camera through a USB 3 port on my laptop ?
Thanks a lot.
TV78
Panic
#2 Posted : Saturday, April 13, 2024 12:56:48 AM(UTC)
Panic
There’s no reason why that wouldn’t work. Although if you need more channels you may have been better off getting a decklink quad 2 and putting it in a thunderbolt 3 enclosure.
Kayo33
#3 Posted : Monday, June 24, 2024 2:42:59 AM(UTC)
Kayo33
Was thanked: 16 time(s) in 12 post(s)
As said before, there is no reason why it wouldn't work.
In your place, I would add a thunderbolt daisy chain device to the aja
a 2nd aja Io3 or an ultrastudio recorder 3g for example
Gyapi
#4 Posted : Monday, June 24, 2024 6:52:43 PM(UTC)
Gyapi
Hi!
Can you tell me such a tool?
Thanks!
Kayo33
#5 Posted : Wednesday, June 26, 2024 7:01:54 AM(UTC)
Kayo33
no tool
thunderbolt devices sometimes have 2 thunderbolt ports. This allows you to daisy chain the devices.
example :
in the case of our friend TV78, an aja io3 + a bmd ultrastudio recorder 3g to have its 5 inputs
as long as you do not exceed the maximum flow rate that the PC's thunderbolt port can support
